FE Power Forums => FE Technical Forum => Topic started by: NewFalconOwner on March 09, 2014, 09:20:36 AM
I removed my timing cover and chain, button and spring,etc.. Im switching to a "newer" cam in my motor, and have the related parts to switch to a thrust plate, button head screws.. there are plugs in the holes I think I drill and tap, but do I need to drill them out or just run a 7-1/6 -14 tap in? Is there suppose to be a big washer between cam and plate as well or just the plate. And what way does the plate go,, the slit on one side goes in or out?
(http://i236.photobucket.com/albums/ff267/new_falcon_owner/falcon/001-12.jpg)
I
I haven't done one of those but I think all you have to do is tap the holes. There is no spacer between the cam and a modern timing gear; the spacer is machined into the timing gear. And you will find when you line up the thrust plate that it will only go on correctly one way; if you have it on backwards the big hole in the thrust plate will not be concentric with the cam.
I managed to put my parka on and go in the garage and tap the hole, and fit the plate on. Now to find a single 4 intake so I can put this cam in and break the motor in.. I really don't want to break the solid cam with the tunnel ram.
thanx
Rick please tell me your NOT going to attempt to use the engine after tapping the block without a complete disassemble of it , you WILL have a failure if you assume you did NOT contaminate the oil passages , Its your money of course
yes I did. I do this on diesel engines for a living, so I do have some experience at this, but thanx.
Ok Brother Best of Luck
thanx a lot for your concern. :) hope all is well with you
