FE Power Forums => FE Technical Forum => Topic started by: chris401 on February 13, 2014, 08:12:27 PM
It has 1.42 primaries 1.55 secondarys. Is this an emissions carb? Anyone know the cfm? I am guessing around 650 to 675.
My '68 shop manual doesn't include it but it has two others with similar throttle bores that flow 446 CFM.
The smaller ones are what I really want but this man is wanting to trade some parts I wont use anytime soon.
Copied from the Mustangtek site. What does open emissions mean? Either?
Full link= http://www.mustangtek.com/4300/4300.html
C8AF-AC
Unconfirmed Application. Information may or may not be complete or accurate68 390 Ford, Thunderbird (w/AT, open emission)
Unconfirmed Application. Information may or may not be complete or accurate68 428 Ford(exc/PC) (w/AT, open emission)
4v
Auto
Ford Service Part Number ID C8AF-9510-AT
If your post over on Ed's forum draws a blank, try VMF:
http://forums.vintage-mustang.com/concours-forum/601653-autolite-1100-decoding.html
Thanks for the guides. The looks like the AC means automatic for 68 390 and non cj 428. Is "open emissions" the PVC hose port in the back of carb?
CFM data here:
http://classicinlines.com/autolitecarbs.asp
http://mustangtimes.net/33-4/pg52-54.pdf
Not sure what the open emissions really means.
Found it! Oddly, it's also from MustangTek's database of PDF'ed documents.
http://www.mustangtek.com/Library6/PDF/ShopTips6-1.pdf
It seems "open" is pre-Thermactor air pump or merely a simple open breather and a PCV system. Closed = Thermactor, air pump, later an EGR valve, etc. Is that how you read it?
I understood open emission the same. Thanks for the info Bob. I also saw a link on fordfe dot com. Cant post link from phone, it said that this carb was a 650. Givin the venturie sizes that makes sense as Holley 750 has 1.72's.
Corrected CFM
