FE Power Forums => FE Technical Forum => Topic started by: chris401 on January 26, 2014, 09:17:38 AM
Title: Dip Stick Oil Pan Match And Identification; More Pictures Added
Post by: chris401 on January 26, 2014, 09:17:38 AM
Lots of inconsistent info I'm finding online. I have a C7AE-6750-A Ford dipstick and tube. What oil pan does this match, how where do I find oil pan identification numbers and does it match a 6qt pan?
Photos are compared to blue, I believe a 66 F100 tube/dipstick and white being the C7AE-6750-A at bottom.
PS: Not asking how to verify correct level with stick.
(http://i1237.photobucket.com/albums/ff469/white65ford/oildipstick1.jpg) (http://s1237.photobucket.com/user/white65ford/media/oildipstick1.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/oildipstick2.jpg) (http://s1237.photobucket.com/user/white65ford/media/oildipstick2.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/oildipstick3.jpg) (http://s1237.photobucket.com/user/white65ford/media/oildipstick3.jpg.html)
Title: Re: Dip Stick Oil Pan Match And Identification
Post by: chris401 on January 31, 2014, 03:59:28 PM
Anyone?
Post by: fastback 427 on January 31, 2014, 04:49:29 PM
Chris, the blue tube looks identical to the one on my 76 f350. The white one looks like the one on my 67 gta fairlane and the numbers are the same as yours.
Post by: chris401 on February 01, 2014, 02:14:07 PM
Does your oil pan look like this one? I noticed the hump in rear was more prominent than on my truck pan.
(http://i1237.photobucket.com/albums/ff469/white65ford/z5.jpg) (http://s1237.photobucket.com/user/white65ford/media/z5.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/z1.jpg) (http://s1237.photobucket.com/user/white65ford/media/z1.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/z.jpg) (http://s1237.photobucket.com/user/white65ford/media/z.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/z4.jpg) (http://s1237.photobucket.com/user/white65ford/media/z4.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/z3.jpg) (http://s1237.photobucket.com/user/white65ford/media/z3.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/z2.jpg) (http://s1237.photobucket.com/user/white65ford/media/z2.jpg.html)
Title: Re: Dip Stick Oil Pan Match And Identification; More Pictures Added
Post by: fastback 427 on February 01, 2014, 06:27:42 PM
No it doesn't. I haven't seen that style yet. How deep is that from flange to bottom? Looks like its a 6 quart from earlier pickup.
Post by: chris401 on February 01, 2014, 06:39:05 PM
The measurements:
front to back= 10"
side to side=7 3/4"
deep= 6"
My early, 1965+, truck pans are all rear drain like in the 70's. This is the only pan I have ever had that drained at the corner. I have had a 64 solid lifter engine, 66 410, couple of Galaxie 390's and a 68 wagon 390. Think pan came from any of these engines?
Link: http://www.network54.com/Forum/74182/message/1390877725/Two+1965+Ford+Trucks%2C+Full+History%2C+39+Years+Old
Post by: fastback 427 on February 02, 2014, 12:18:41 PM
I'm at a loss on your pan. There should be a number stamped into the pan somewhere. Hit it with a scotchbrite pad and check closer maybe?
Title: Numbers Location?
Post by: chris401 on February 03, 2014, 04:09:50 PM
I was going to paint this pan and found it needed more work. Ill glass blast it again. What area do I look for identification, part or casting number?
Post by: fastback 427 on February 03, 2014, 06:04:26 PM
Should be in the rear of the pan. Might be easier to see from the inside. If your gonna glass bead the pan make sure to scrub the heck out a it. Did the same on an aluminum intake years ago and played hell cleaning it up on the inside!
Also check the center under the pickup as I've seen them both.
Post by: chris401 on February 03, 2014, 06:31:14 PM
Ill do that and post back. Here are a couple photos of my truck pan (1974+/-) with fresh paint.
(http://i1237.photobucket.com/albums/ff469/white65ford/oilpan2.jpg) (http://s1237.photobucket.com/user/white65ford/media/oilpan2.jpg.html)
(http://i1237.photobucket.com/albums/ff469/white65ford/oilpan3.jpg) (http://s1237.photobucket.com/user/white65ford/media/oilpan3.jpg.html)
Post by: fastback 427 on February 03, 2014, 06:47:53 PM
Looks good! What color and brand paint did you use?
Post by: chris401 on February 04, 2014, 09:06:55 AM
Thanks. Dupl-Color DE1606
