FE Power Forums => FE Technical Forum => Topic started by: Blueoval429 on December 27, 2013, 12:07:08 PM
Title: Syncromesh Trans Fluid
Post by: Blueoval429 on December 27, 2013, 12:07:08 PM
I installed a Tremec Magnum 6-speed behind a warmed over 390 in my pickup, Woodstock.  It now has the 500 miles on it for break in and time for the fluid change.  The recommended fluid is either GM Syncromesh or Pennzoil Syncromesh.  From what I have read, they are the exact same except for price.  There is also a Castrol brand available and perhaps others.  Any recommendations from you guys?
Title: Re: Syncromesh Trans Fluid
Post by: drdano on December 27, 2013, 06:38:08 PM
I've used both the GM and Penzoil versions, didn't notice any difference between the two.
Post by: My427stang on December 27, 2013, 10:07:16 PM
Same here, matter of fact I used a bench blend last time in my TKO-600, some Mopar ATF+4, some Dexron and whatever else I had around.  Been shifting so nice since 2007 I don't want to change it out LOL
Post by: Monzy on December 28, 2013, 06:20:59 PM
I've been using the GM Syncromesh without any problem.   I believe that's what is recommended by Tremec so might as well use what they say.   Don't worry that GM blood cant get back into the motor.  ;)
