FE Power Forums => FE Technical Forum => Topic started by: NewFalconOwner on December 14, 2013, 09:42:18 AM
I have a 352HP from a 60 tbird, was rebuilt 4 yrs ago (10.5compression,etc.), and the guy pulled it out last yr and put a 390 in his bird to sell and I got the motor. Anyways,,
I have a custom grind comp solid flat cam, lifters ,chain, adjust rockers, ect.. but still has the stock C0AE heads on, but I want to put the solid in.. Ive read a lot about removing inner springs on recommended valve springs, so would it be safe to assume, I can install the solid cam and parts and use the stock valve springs in the 352 heads for break-in purposes, and when my C4's get rebuilt I can just swap heads and not worry about it when I do?
I'd say go for it. One could pull one or two springs and measure the spring pressure open but with a well-used head, they likely aren't even close to the originally low factory specs when new.
thanx,, once the chain shows up,, I will get things organized, :)
I would at least check for coil bind because the results could be bent pushrods and resulting damage.
yeah thanx, good point
Bingo, I seriously doubt the stockers will handle anything over about .530 lift, and if you run lash loose, you'll be hammering the lifters so hard it is probably better to just run the big springs
so I should wait till I get the heads done, or at least springs good enough to run the cam.. few more months wont hurt I guess lol
Sorry for the hijack but you say you have c0ae heads now (i assume c0ae 6090 c) and your changing to c4 (I assume c4ae 6090 g) aren't the the same head? If not, whats the difference? Has anyone flowed both? For that matter the c1ae 6090 a heads look exactly the same too...
they are stock 352 heads, and they are broken on the exhaust ears on each corner, but they work for now. the c4's are H, and they are bare, but I have CJ valves and some port work going on and no broken ears on the exhaust.
and I run the motor every once in awhile to hear it and get motivation. if I pulled them off to rebuild Id still have broken ears and exhaust leaks which sux.
http://www.youtube.com/watch?v=dP8-aoYeyvs
1 carb wasn't working good, but the motor worked awesome before the dual 4 install, but I had to try it out even though a bad carb and no exhaust system and home made headers that had leaking gasket areas
