FE Power Forums => FE Technical Forum => Drag Strip Results for FE Powered Vehicles => Topic started by: 6667fan on November 14, 2026, 06:44:54 PM
Finally got rebuilt engine to track in September. Made a few more visits in October. Bunch of 10.6s-10.7s. ( car has been 10.55 hence the underwhelming term). This version of engine has 64 more hp than the last build so not a power problem and it ran well all trips. It’s the little stuff that tripped me up like poor launches, headwinds, track oil downs,( netting very few total passes). Stuff that gets us all at one time or another.
Upgraded the clutch linkage which was an ordeal as I removed the swing pedal assembly and had Mustang Steve bearing assemblies welded in. Removing/ replacing the assembly is a job I would not wish on my worst enemy. The rebuilt swing pedal fixed slop up top. A custom Z bar got rid of some slop down below. The factory setup is rife with deflection. That’s been taken care of.
I do have something to look forward to next season as in trying to make improvements. Job one is to get rear axle under control. Too much up & down with slicks. Plan is to replace the 9 ways with some DAs and experiment with the psi in slicks.
I get it. It happens a couple of years ago I only went once. My new motor has 60 more horse and somehow only got 1.5 tenths. Put 600 dollars worth of split mono leafs and got a little over 2 tenths. Maybe there’s something your missing. Saw the video you sent me it sounds good.
You didn't mention weather conditions on your .55 run vs your .60 and .70 runs, which definitely can make a difference. Your 60' time seems to be in line with your ET, but have you played with the clutch any to try and get the launch smoother? The clutch hitting too hard really upsets the rear and can cause it to 'bounce', which is a problem I have with my heavy street clutch. Also, not sure if you have them, but at this stage, you (and me) should be using a slider type rear spring hanger, which helps get a smoother transition to extension and separation on the rear, especially with stick cars like ours. Stock type hangers and compressed rubber bushings like the factory uses don't help at all.
Just curious, have you tried a lower gear with the new engine? If you have a 4.5* gear set, the car might like it with the added power/torque.
Running in September/October the temps/humidity were decent. One trip had significant head winds, that hurt. I knew it would be blowing but went anyway.
Car has leaf spring relocators so sliders are complicated. Have considered Del-Alum bushings.
Clutch is adjustable, has a lot of base but car is still street driven. I will take some out if the other ideas don’t make progress.
Best take away was the 4.57s helped the engine at end of track. It was still pulling and the mph increased from 127 to 129
That's definitely a drawback to doing double duty, street and strip. Most of the Drag Week guys running slipper clutches will add base before the drives, then take it out for the track. That's the best way, but that involves making an adjustment hole, which makes the bell unable to be recert'd. Not really an issue if you're not running NHRA events, but still kind of stinks.
I have talked to at least one guy that did not add base when driving, but they strongly remarked about having to be gentle on the street, meaning NO heavy footing whatsoever. That would really take a lot of the fun out. :) The added work of making changes before each type of driving is a pain, but that's just a decision we have to make for ourselves.
