FE Power Forums => Non-FE Discussion Forum => Topic started by: AlanCasida on November 05, 2026, 09:44:10 PM
Title: T18 or C6 for towing
Post by: AlanCasida on November 05, 2026, 09:44:10 PM
Right now my 390/410 is at the machine shop and while it's out, I have an opportunity to make a transmission change. I currently have a T18 with a GearVendor overdrive in it. I've had it in there for a long time(maybe 20 years) and while it's been fun, it doesn't have the appeal it once had. When I got the truck it had a C6 in it, so I have all the stuff to put it back. I have a C6 GV adapter too so it will go back in also. I may be using it to tow my open car trailer some so I'm just wondering what some of you guys "of a certain age" prefer. It's a 1967 F250 with 3.54 gears.
Title: Re: T18 or C6 for towing
Post by: 475fetoploader on November 06, 2026, 10:04:34 AM
Don't ask me, I think everything needs a clutch pedal
Post by: FrozenMerc on November 06, 2026, 01:16:26 PM
I have/had both.  I will take the T18/19 over the C6 any day of the week.
'76 F250, 390, 4bbl, Cam and Headers, C6.  It would pull my 24' enclosed just fine, comfortably even, but without overdrive, 65 mph was about all I was comfortable with on longer hauls and typically interstates were avoided.  With the right gearing, I think it could have been made to work fine enough, for a slushy 3 spd auto.  I ended up going down an ill-fated AOD rabbit hole and eventually sold the truck.  Couldn't get a torque convertor with a low enough stall and small enough diameter to fit the AOD-FE Quick Time bellhousing.  It would cook the fluid at interstate speeds.
'85 F350 DRW, 7.3 IDI, Turbo, Cam, Big Pump, T18 + Advance Adaptors OD.  This truck was beyond worthless without overdrive.  4.11:1 rear axle and 3200 rpm redline meant 64 mph top speed, and no one wants to listen to a mechanical diesel sit on the redline for extended periods of time.  Swapped in 3.73 gears and the AA OD and it made a world of difference.  Cruises wonderfully at 75 mph - 2500 rpm.  The engine is right in it's primary power band so it has no problem tugging the big white parachute along.
(https://live.staticflickr.com/65535/54467591264_f2c4de12f3_b.jpg)
Post by: frnkeore on November 06, 2026, 04:47:55 PM
The "75 mph - 2500 rpm" +/- (30 mph per 1000 rpm) is always my goal, when gearing for a street car.
Something that hasn't been mentioned is using a 4sp truck trans, using 1st as a regular 1st gear and not as a extra low gear. The T19 is perfect for that.
These are 9" gear examples of how to use it that way. Note the mph/1000 and tire diameter. As tire size goes up, gearing can come down. Divide mph/1000 by tire dia then, multiply your tire dia by that number and it will give you your mph/1000.
Post by: RustyCrankshaft on November 06, 2026, 08:02:52 PM
Neither, especially for towing. I prefer something with OD. I have swapped several OD automatics in my old junk over the last few years, cars and trucks. I also have a ZF5 speed swap in one big block F350 and I'm probably going to swap a TR4040 into my 73 F350 next because ZF5 speeds are getting real expensive at the wrecking yard.
Post by: frnkeore on November 07, 2026, 04:01:17 AM
Here's a example with the T18 and 33" tires and 3.25 gears.
1st is a little low for everyday use but, would be good for heavy towing and 2nd would still be usable as a first gear for everyday driving.
Post by: AlanCasida on November 07, 2026, 02:31:02 PM
Thanks for the comments but what I was really asking about was the durability of the T18 vs C6. As in, how do they hold up under similar conditions.
Post by: FrozenMerc on November 09, 2026, 10:32:17 AM
As far as durability, The T18 really is bullet proof, especially in Class 2 and 3 vehicles.  Ford and IH both put the T18/19 in some medium duty applications (Class 4, 5, and 6) where the only automatic option was an Allison, not the C6.
Post by: My427stang on November 09, 2026, 01:15:40 PM
Man towing with an automatic is nice. I'd look hard at quality converters, a good shift kit, and good rebuild parts.  I am not a converter guy, but seems like there has to be a way to get around the stall/heat challenge when loaded heavy.
Of course an open car trailer is nothing like a 24 foot parachute too....LOL good analogy!
Needless to say the T18's are strong, other than replacing clutches, but for me, dropping an automatic in gear with the trailer behind me is real nice.
Post by: galaxiex on November 09, 2026, 04:28:54 PM
The C6 is a very rugged trans even stock and built right it easily holds up to towing.
In ALL cases a good large hi capacity auxiliary cooler is a MUST!
How much weight do you plan on hauling?
How is the engine built?
Stock?
Lots more power over stock?
Cam?
All that would determine to what extent the C6 would maybe need upgrades.
For example; more clutches in the drums, 4 pin rear planet, what level of "shift kit".
If the cam is mild, a stockish "low stall" converter is the way to go.
Maybe an upgrade like furnace brazed or TIG welded fins.
The sky is the limit on converter and trans upgrades.
How much will you need depends and HP and loaded weight.
No worries about the GV unit, it will take almost anything you can throw at it.
Post by: Rory428 on November 09, 2026, 09:10:11 PM
With only 3.54 gears, I am surprised that you would ever use the Gear Vendors OD while towing. Personally, I strongly favor a manual transmission, for 26 years, I hauled my drag car on my 1974 F350 DRW ramp truck/car hauler, which typically weighed around 10,500 pounds loaded. My truck had a basically stock low compression 390 from a 1976 F250, other than a generic "RV" cam, a pair of Hedman headers, and an iron "S" code intake with a vacuum secondary Holley. It had a NP 435 truck 4 speed, which I believe has similar gearing to a T18, and in those 26 years, the NP435 never had any issues. It also had a Dana 70 rearend with 4.10 gears, and 32" tall tires (7.50R16 Michelins). At 60 MPH, it revved 2600 RPM, and the 390 seemed quite happy there, and rarely needed a downshift on all but the steepest grades. On a 1000+ mile trip  from Vancouver BC to California, it was able to climb the long steady Siskyou Summit in Southern Oregon/Northern California in 4th gear. For the past 13 years, I have been towing my 24 foot enclosed trailer, which usually weighs between 9000 and 10,000 pounds, with my 1999 F350 Dually, with a V10 and 5 speed manual, with 3.73 gears. The majority of my towing is in 4th gear, which puts the RPM about where the 74 truck was, 2600 RPM at 60 MPH. If I use 5th gear, the revs drop down lower than I like, just below 2000 RPM. That would be fine with the truck empty, but with 5 tons behind, any hill at all wants a downshift.
Post by: RustyCrankshaft on November 09, 2026, 09:25:49 PM
The T18's are ok, but the NP435's are one of the best pickup 4 speeds IMO. I've had quite a few of them over the years in all sorts of stuff and they've been good. My 84 F800 service truck had a 370, NP435 and 2 speed diff when I got it. The 370 was tired so I swapped a 460 in it and then later on a 521. The 435 got rebuild once, but it was working pretty hard in that application and it never left me stranded.
