FE Power Forums => FE Technical Forum => Topic started by: 1967 XR7 GT on September 11, 2026, 06:26:11 AM
Title: Holley 3 Barrel 950 & 1050 CFM Tuning
Post by: 1967 XR7 GT on September 11, 2026, 06:26:11 AM
Basic Info: 66-67 Holley introduced the 3 Barrel for public consumption. In 1964 Chrysler had Holley build them a carb list #3085  for their Nascar Hemi motors and this was the Holley 3 Barrel. There has been no info as to tuning issues with the Nascar version.
Now, 66-67 with the introduction of the 3 Barrel to the public, some how emissons became involved and the carbs were tuned to meet those standards. In this case the Emisson standards seem to go towards leaning these carbs out. I don't know if Holley ever tested these carbs or if the changes were just done on paper.
For such a large carb Holley had installed .040" PVCR's in the primary metering block #5615 to lean the primary out to meet Emission Standards, resulting in a flat spot, the initial fix was to go larger jets which caused it to run pig rich, so now this is just the primary issue, now the 2ndaries were also lean and at wide open throttle there was a substantial bog from being to lean, an idea came up for a fix, which was to remove the vaccum canister and make the primary and secondary one to one, so gears were made, and a primary shooter was extended to the secondaries for a fuel shot to richen up the secondary during the lean peroid during blade opening.
Previously, everything done were just Band Aids and didn't NECESSARILY fix any of the issues.
The Nascar's 3 Barrel metering block #4328 came with .093' PVCR's and they had emulsion tubes in the main well reducing fuel flow, so the larger PVCR was needed.
Now, the newer 3 Barrels came with metering Block # 5615 and had a .040" PVCR, and does not have emulsions tubes in the main well, and the primary side of the 3 Barrel is basicly the same as the primary side of the Holley 850 Double Pumper, so tuning is about the same. The PVCR's in the metering plate of the 850 DP are .070" and also do not have emulsion tubes in the main well.
So, to tune the 66-67 and newer 3 Barrels, you open the PVCR's on the #5616 metering plates from .040" to .070" and proceede to tune the 3 Barrel primary's the same as you would an 850 DP consiting of the fuel mixer screws, the transition circuit, primary jets and power valves. There are plenty of tutorials on line for tuning an 850 DP for referencing if you have questions. I'll add more later concerning the tuning of the 2ndarys, actually half of it s getting the primaries tuned.
Title: Re: Holley 3 Barrel 950 & 1050 CFM Tuning
Post by: 428kidd on September 11, 2026, 07:05:53 AM
Thanks for posting this i have a few 3 barrels i always wanted to try out. I remember Barry R doing some dyno work years ago and the 3 barrel beat them all except a dominator. So just drilling the hole from .040 to .070 is the first step?
Post by: 1967 XR7 GT on September 11, 2026, 07:16:28 AM
Thats correct .040 to .070. 2 holes under where the power valve screws in. The Dominators replaced the 3 Barrels I believe it was 69, thats why no further development was done on the 3 Barrels. And  Holley has the 1050 @ actually 1030 cfm.
I remember that Dyno run, I think I remember one of the other carbs being an HP 950.
Here's the link.
https://www.youtube.com/watch?v=F38HumC41uY
Post by: Drew Pojedinec on September 11, 2026, 09:42:00 AM
Is standard procedure for most any builder. .063-.076 depending on engine characteristics.
I like to make the pvcr removable so that end is tunable. Makes it nice to find a happy cruise jetting and adjust your wot fuel.
A nice touch is to add a restriction on the face of the VS housing where it attaches to the main body as well.
Allows you to tailor the restriction without taking apart the housing and potentially ripping the Vs diaphragm. Metering plate main feed can be done the same way.
Would be very enjoyable to dial one of these in on a dyno with these three adjustments.
Post by: 1967 XR7 GT on September 11, 2026, 04:51:50 PM
Inlarging the PVCR's from .040 to .070 allows sufficient fuel were the previous lean condition was, allowing the main jets to be properly tuned instead of causing a pig rich condition covering the lean condition caused by the to small PVCR's in the circled in the power valve mount.
The 2 holes circled to the left, the hole to the right feeds the transition slot in the throttle plate and the channel the hole sits in at the top connects to the main well. The hole to the left is for the air fuel mixture and feeds a hole in the throttle plate below the transition slot and the butterfly. The butterly needs to cover the majority of the transition slots in order for the air fuel adjusters to work, usually about .020" is uncovered.
To set the idle and to keep the transition slot mostly covered so the air fuel mixture screws work, some times the 2ndary is open slightly to increase idle, or holes are drilled in the primary butterflys to allow air to flow to increase idle allowing the air fuel mixture screws to work.
For fine tuning, sometimes the idle fuel restrictor which is to the right of the 2 holes circled is removed and relocated to the top of the channel from the right hole in the transition circuit that connects to the main well at the top, the connection to the main well is taped for adjustable idle fuel restrictors for fine tuning, which may or may not be necessary, just because it can be done doesn't mean it needs too.
Once the primary has been sorted and the throttle operation is smooth and trouble free, then the 2ndry tuning can start
Post by: 1967 XR7 GT on September 16, 2026, 09:04:06 PM
Some 2ndary tuning info:
The Holley list 4604 S 1050 cfm 2ndarys come with no.4 metering plate, which have .093" metering restrictions which convert to no. 80, 81 and 82 no. main jets, the chart converts .093" to all 3 jet sizes, but I go with the larger #82.
The Holley list 3916 1S 950 cfm 2ndarys which I have one and can't find it to see what metering plate it has ? I did find one on Ebay, and it shows that, that 950 came with a no.26 metering plate which converts to a no.78 main jet, I don't know if that was the original plate the 950 has, seems reasonable but will check into it later.
Mutiple plates for jeting can get expensive. So I went aftermarket and went with a Proform plate that allows the use of regular jets. The quality was a little lacking, so I did a little clean up to fix the issue. Besides the Proform plates theirs QFT and AED that use regular Holley jets, and their's even a couple of no name plates also.
For tuning, their's a 7 spring kit for the 2ndary vaccum canister, each of the springs have a different tension to taylor the opening of the secondaries, it's just time consuming removing the vaccum housing each time to change the spring, the stock spring is usually the black one the heaviest. I like the under load test to confirm the proper spring
