FE Power Forums => Non-FE Discussion Forum => Topic started by: bsprowl on June 16, 2026, 02:47:39 PM
I'm tired of my 2000 F-250 having a one wheel drive. I looked at my door tag and the axle code is blank but I only have a 5.4 engine so I guess the axle is a Ford 10.25.
Summit has a PowerTrax Right-Lock for a Ford 10.25. The description says installation can be done with common hand tools so I think I can just take the old spider and and install the PowerTrax - I don't have to worry about ring and pinion clearance if put every back correctly.
How do I tell if my differential is actually a Ford 10.25?
A little word of warning. A friend of mine just recently went through that. He has a 2000 f250 crewcab with the 7.3PS. He pulled his apart only to find the differential in his truck was the 3 pinion design which neither Powertrax or anyone else makes that type of locker for. His was the 10.5. After 2013 all F250s had the 3 pinion differential but I did a little research, and it was possible to get one clear back through 1999.
That particular product (and anyone else's) that mounts, that in the fashion of in the O.E.M. case on the pinion cross-pin(s), is really of poor engineering execution from the standpoint of strength. Aka. it ain't no Detroit Locker! ;)
Scott.
You can get TruTrack's for the Sterling axles and I much prefer them over the Powertrax or a clutch type limited slip. Your truck has a 10.5", but for simplicity just about all the aftermarket stuff uses 10.25" stuff so it's backwards compatible.
That’s what my friend did. I believe he got the Yukon version of the Truetrac. It ended up being a blessing in disguise since he found worn carrier and pinion bearings that he would not have caught by putting in a Powertraxx unit.
On the subject of excessively worn componentry, it seems these units suffer from failures in the sense that the carrier bearings have a habit of turning, both on the inner race to differential snout, but more concerning, of the outer race in the axle housing under the caps; so be sure to inspect for this. ;)
Scott.
I'm surprised the truetrac isn't standard in any rear wheel drive street driven and occasional off road vehicle. Imo, it's more useful than a lot of the geegaws installed as standard equipment.
To bsprowl, I believe a rear stabilizer bar will accentuate the one wheel drive of an open diff. If not hauling a slide in camper or other tall loads might try it without...if you have one.
Bob, years ago I fiddled around with various lockers in my 10.25" Sterling differential in my 1990 F250, (7.3LIDI diesel)
From the factory it had 3.55:1 gears with an open style differential and the short style pinion, and about 60,000 miles on the whole thing.
I needed both wheel traction for MN winter driving.
I tried using one of the Powertrax Lock-Right lockers (lunchbox lockers) and it installed really nice, but the first one did not work properly. I was basically a full spool.
Summit was great with the return and sent me another whole unit to try after some discussion proving to them I'm not an idiot and I did not screw things up during installation.
2nd Powertrax, same easy install, but by this time I had researched quite a lot about these things and knew more concerning various clearances.
I installed the 2nd unit only to find incorrect clearances. Everything fit and installed, but things were too tight... but I had all the new parts from the 1st unit too so I started measuring, swapping, fitting, and doing what I could to install this thing to "perfect" specs per the manufacturer.
Installed, measured, verified... driven... still a spool with no differential action under any conditions.
After much trial and error, I was eventually on the phone with one of the engineers at Powertrax.
We spoke about my issues, he agreed I was doing things correctly and saw a video I sent to him regarding clearances and such.
Finally, he admitted that some Lock-Rights just don't work well in certain differentials, with the Sterling 10.25" being one of them... Basically it is a gamble if it will work properly or not.
My next choice was to install a Yukon Grizzly (their version of a Detroit Locker).
That was more than 100,000 miles ago and the only issue I have had is the 3.73:1 gears are a tad howly.
I have changed the lube four times since initial install, with the first two happening after break in miles, then again after a long haul to the East coast and back, otherwise I has been normal maintenance.
I would recommend you get a Yukon Grizzly, install it, and forget it beyond lube changes.
Money well spent in the long run, and you get useful traction all the time.
There are a couple oddities with the Yukon locker.
1) Both rear tires wear a bit quicker than with the open differential due to the skidding around corners more than an open, but the Yukon does allow slipping the majority of the time
2) Both rear tires wear relatively flat across the tread due to the locker too... This makes tire rotation easy to remember each season (I use winter tires and summer tires)
3) Occasionally, under certain conditions, you will experience throttle steer as the locker engages/disengages or stays locked while cornering.
This had only been noticeable when the truck is unloaded, or lightly loaded in the bed only, and while traversing long curved on/off ramps like some highway exchanges use.
There is one I drive many times per week that is basically a long, sweeping curve at highway speed and this is where I experience this anomaly caused by the locker.
4) Sometimes, very rarely, I will hear/feel the differential locking/unlocking in a harsh manner when driving on really slippery winter roads when one rear tire has a lot more traction than the other. Usually when slowing to a stop and an intersection and when one tire is basically on ice and the other having some traction... but this is rare. The clunk, however, will get your attention.
Never have any of these anomalies caused anything even remotely dangerous in terms of driving response and feel. These are just things I notice because I notice these things. I think most people would just drive and never give it a second thought.
Anyway, I have over a hundred thousand daily driver miles with a Yukon Grizzley locker in my 2wheel drive, 3/4 ton truck and I believe it has made my truck better, and safer, to drive year round in Minnesota conditions.
I have heard some rumors that Yukon has changed in quality over the past few years so look into that because mine is pushing 15 years ago that I purchased and installed it.
Thanks for all of the replies. I will check out the Yukon Grizzly.
Not trying to sell truetracs but am curious why would one choose a detroit locker/grizzly locker over a truetrac. I think of the lockers as more for dedicated offroad/rock climbing.
You'll never know a truetrac is there (no noise, no weird tire wear, no unlock scenarios), it will last longer than most trucks, and in the odd chance one tire has zero traction you can make your tire that has traction spin by feathering the parking brake...I've done that.
I like Detroit lockers and pick them because I have lots of experience with them. Never had issues with tire wear, and only one unlocking issue in 30 years of driving them (in the rain, going too fast around a sweeping curve, minor blip from the rear end). The new ones are very quiet, and the old ones sound cool in the right car, IMO. They also "fit" with a 1960s performance vehicle. I think the disadvantages of Detroit Lockers are WILDLY overstated online. And Truetracs just don't have the same appeal...
Any of the "worm-drive" type units provide a resistance function through a combination of leverage and friction and hence do not necessarily establish "one for one" in rotation for each engaged tire; this vs. the "Detroit" which through direct acting gearing provides absolute "locking" if one tire should attempt a "runaway". And of these worm-drive units their effectiveness is known to lessen with usage. :)
Scott.
The Yukon is more than I want to spend. And I was hoping to avoid cost of setting the ring and pinion. The Eaton Truetrac may be what I get.
Bob, I found a used factory limited slip on eBay for a couple hundred bucks for my 01 SD. Maybe I got lucky it was good, but slapped it in and it served me well.
No idea what tires you run on the back but for the money, if you're currently running an all-season then a tire like the Goodyear wrangler duratrac is equal or more valuable than any differential improvement. In other words, given the choice of an open diff with a proper snow/mud tire or any type of locking rear end with all-season tires, I'd take the open diff with snow/mud tires.
All-seasons are fine on dry and wet pavement but when it comes to use on wet grass or snow they've helped sell a lot of all wheel drive and 4wd automobiles. I used to think guys were pulling my leg saying they need 4wd on wet grass until dad got a used pickup that had all seasons...it could barely move on wet grass. Swapping on some proper rear tires made a world of difference.
In fact, it's probably heresy but my '87 mustang with open differential, snow tires and some weight near the tail lights was way, way, way more capable in snow than any front wheel drive car fitted with all seasons.
Another option is the Eaton E-locker. They're a factory option on newer Super Duty's and swap into the older Sterling's with just changing the tone ring. I've found several in the yards around here for under 100 bucks. The E-lockers are pretty tuff. I have one in my trail truck in the front Dana 60 on 40's and so far I haven't hurt it.
Jay has a good reply regarding Detroit Locker differentials. And his mention of the overblown reputation concerning Detroit Lockers and online lore is spot on... WAAAAY overblown concerning the negatives of a Detroit Locker as compared to the hundreds of thousands of miles driven using a Detroit Locker I have experienced.
I fully believe part of the overblown lore stems from many vehicle owners not being well versed in how to actually build and modify chassis and suspension parts properly so they result in various inequities they built into their off roader, hot rod, collector car, or whatever via poor design and application and mechanical work and then blame the Detroit Locker for the weird driving results.
In my post I did state the various things associated with using a Detroit locker, both from a toy vehicle use, and daily drive vehicle point of view, because I want to be as honest as I can be when making recommendations. What I did not post are some of the real life issues I have witnessed when people complain about how poorly a Detroit Locker drive... Perspective is everything here and this is something you don't get with the vast majority of online reviews, posts and comments, regardless of the literal content.
For instance, a guy I know will strongly advise against running a Detroit Locker based on his direct experience. His experience is real, but perspective matters.
What you don't know is his direct experience, while real, comes from the perspective of a 1966 Chevelle running a home built 4-link rear suspension, a 600+HP big block, a 4spd manual... and running wrinkle wall drag slicks on the street, because this was his street race toy back in the late 1980's early 1990's. That car was really fast, and it was a handful to drive on the street too.
Another guy I knew had a K20 Blazer with Detroit Lockers in the front and rear differentials, and he bitched constantly about how horribly that thing drove because of the Detroit Lockers.
What most people never knew was that K20 was running 44" tall TSL Swamper tires, using a really high lift kit, and a bunch of cheaply done modifications to get it all to fit, all coupled to a 500 HP engine and mainly used for off road screwing around... But it was licensed and insured for the road so he drove it on the road even though he should not have.
My point... when reading the reviews about Detroit Lockers you really need to understand the perspective of the writer of the review because often, they are driving a poorly executed vehicle that would have driven terrible no matter what differential was installed.
The rear tires will wear differently than a vehicle with an open differential, but that does not mean they wear out super quick. I'm still getting 50,000+ miles out of my tires when using a Detroit Locker... Unless of course the tires are very soft compound. But normal road tires last a long time without issue (I do maintain proper inflation pressures and rotate tires regularly and this has proven to maximize tire life and use over the tires treadwear range) But they do wear differently than a vehicle not using a Detroit Locker differential.
The differential does make some noise, but once you know the noise is normal it merely becomes part of the operation of a Detroit Locker with little clicks and pops here and there... It lets you know it is still working while not being intrusive.
The locker does give rise to some driving differences, most notably when traversing long, sweeping curves, but this too becomes just part of normal driving with a locker and before too long the actions are just normal routine.
The HUGE plus of a Detroit Locker is the set it and forget it aspect.
Of all the various differentials I have driven over the years NONE of them are as durable, or as consistent, as a Detroit Locker.
Install a Detroit Locker correctly, and do the required lube change maintenance, and the next time you need to mess with it will be when the carrier bearings need replacement, or you literally break the differential in some manner through hard abuse.
The Eaton True-Trac is a good Torsen style differential, and it does work well. But it is not as consistently positive, or durable, as a Detroit Locker differential.
Appreciate your explanation cleandan. The one draw back I see for the detroit locker is that it's either locked or unlocked (i.e. open). I'm guessing/assuming the locker is open during all turns. I can understand that is fine/preferred for a lot of folks, though I wouldn't want that for the way I use them.
In the barn yard or pasture field towing/hauling I like to have both tires pulling including while turning. In a rare case where one tire tends to free spin with a truetrac I can temper that with the parking brake.
My only comparison is the manual lock on 2wd tractors. They're either locked or unlocked. Locked is good on a long, straight pull but it has to be unlocked for turns. Navigating turns I'll bias the differential by feathering the right or left brake as needed.
I can see the locker and truetrac as being meant for different situations.
Utilization of the parking brake is a standard practice executed when the vehicle is solely equipped with an open-type differential. The "idea" is that whatever enhanced turning force that is required in overcoming the resistance created in the braking force as being applied to the free-spinning wheel is also being distributed to the non-turning, better planted wheel. And by halting the spinning wheel, provides a torque rise in the drivetrain, this creating an enhanced resistance of rotation within the differential that "might" also participate in giving the other the chance in participation.
And the admission (repeatedly) that one is required to do this in order to achieve reasonable effect from the worm-geared assembly is evidence of it's unacceptability in the application. ;)
Remember, the Detroit Locker is a "ratchet system", either wheel (only one) may turn faster than the ring gear, and this is the "differential" function effect; as when navigating a turn the outside wheel is allowed to accelerate ahead of the ring gears' turning rate. It's just that neither may turn slower than the ring gear. Therefore, technically "lock-up" only takes place when one wheel begins to fall behind and is then gear-locked to the differential.
The ratcheting and sometimes resultant "bang" is generally experienced on hard pavement, when for example, traversing through a turn under moderate throttle, the outside wheel is unlocked ratcheting forward ahead of the ring gear, the drive torque is now being applied to the inside wheel as it is the slowest and is locked to the ring gear, and then when greater drive torque is applied in coming out of the turn, the inside wheel breaks lose (just a little) and slips forward enough to catch-up to the out side wheel, which then as the inside wheel is now the faster, the outside wheel is grabbed by the geared ratchet mechanism, the engine torque isn't great enough to maintain both wheels at the spinning/slipping speed, so you get the "clunk", maybe a little upset from the suspension and nothing more. :)
Of course, particularly with leaf spring systems there can be significant axle wrap-up that'll accentuate this; and an unknowing passenger saying what-the-F#@k! ::)
Scott.
These are fun discussions.
The 3 differentials that I personally are familiar with are the Ford Traction Lock, Lock Right lunchbox locker, and the Detroit Locker.
The Traction Lock is the only one of those that is completely invisible to the driver and they work pretty good. The only downside to a clutch style posi is that when it quits working that is invisible to the driver too...until you notice that only one tire is spinning. In reality a factory style clutch limited slip would probably be ideal for the original poster.
Since the lunchbox style lockers were mentioned I throw in my experience. Yes, having the strength of the differential rely on the cross pin of the carrier seems "iffy". I had a Lock Right front and back on our '87 Jeep YJ and did the Rubicon and most of the other major trails in the West. Never a failure although I have a Detroit in the rear end now because I switched to a 9 inch and had the Detroit on my junk pile. The front still has the original Lock Right and it works fine.
All of my FE powered hot rods have had Detroit Lockers. Mostly because you can buy used NASCAR lockers from Ebay for less than $300. The strength is legendary. My stuff is usually tubbed so the rear end gets stressed every time out. Never a failure.
I will admit that my hot rods and my Jeep would drive crappy with open differentials. The point I'm making here is that the lunchbox lockers and the NASCAR takeout lockers behave nearly identical. They click 'n clack sometimes loudly, and get weird in long sweeping turns. Without reason they will sometimes NOT unlock when going from a stand still to a right turn. That said, it's nothing so abrupt that I wouldn't allow my wife or friends to drive my cars.
That's not quite what I said. I said "...in the rare case...". I've had one tire on wet grass and one on dry concrete. Stomped the gas and left rubber on the concrete.
In my application (slow moving heavy loads) I prefer the seamless transition of torque to the tire with traction. The slip and grab action of a locker doesn't sound like something I want for my application though I can understand why other applications (like racing or rock crawling) wouldn't even notice the slip/grab action.
I think the military hummers also have a torque biasing differential...like the truetrac. So I don't think there is a one size fits all...choosing the locker or the truetrac is partly personal preference and partly different driving needs.
I have a couple of pals that have Truetracs in the front end of their Jeeps. They like them a lot and they seem to crawl on rock as well as my Lock Right does. They do not make the snap, crackle, pop my locker does. I believe they'd work as well in the rear end but I have no personal experience with that.
As I recall, the "Truetrac" product hit it's stride along with the 4 X 4 craze in the late '70's. Back then "posi", "limited-slip", "trac/tion-loc, etc. (whatever!), was available from the O.E.M. for the rears, but other than for the Bronco, not for the front axles. Then the tires got bigger, and soon something other than the clutch type differentials were necessary if one actually expected both tires to be turning, particularly in the mud! ::)
For the rear Detroit Lockers were for the well-healed, for the less so, "Lincoln-Lockers" (welded) became popular; but what for the fronts? Either of these, though truly "positive locking" and ensured that all four (4 X 4) were going to be turning in the mud, how could one ask for more. But particularly as with the front axle, if all of the tires are "locked" together, turning exactly the same revolutions at all times, surprisingly when off-road on a lose surface, you can turn the front wheels to the left or right, but the vehicle doesn't readily change direction! Been there dun that! ;)
So here comes the Truetrac, with that "seamless" differential action that allows the tires to differential when the wheels turn left & right and it works great; but the observant operator realizes that although this product is truly superior to the otherwise "open" unit, it isn't as positive as the "locked" assemblies as it surrenders to the external environmental factors acting upon it's function. But for the front axle this was an acceptable compromise for greater civility and was in that frame of mind that it was initially marketed. :)
Later, as the engine torque outputs have increased, and the public finds new ways to test their vehicles, you'll note that some of these worm-gear guys are now coupling "clutch-packs" to their units. The purpose here is to provide a certain sum of "preload" to the gear-sets to aid in their functionality; something akin to the idea of applying the parking brake as mentioned previously. Note that these are "torque bias" in operation, in other words, if one wheel is off the ground, there's a minimal torque application involved to make it turn, and therefore not so great a value being applied to the opposite side either. :o
And hence, I would think would be a 'very' poor choice for something particularly like "rock-climbing"! :)
Scott.
There's a scenario with the Detroit locker that I cannot figure. Let's say I'm pulling a truck with trailer combo that grosses 8 ton. I'm on a marginal traction surface...slick grass, snow, whatever.. I'm in low gear because I'm in a driveway, field, etc and both rear tires are working to keep me moving. Now I need to make a 45 degree or more turn. How does the outside tire increase speed so it can unlock? And if it can unlock, how to I keep moving?
Remember, this is with a 2wd F250...I believe that's what the OP has.
There's a scenario with the Detroit locker that I cannot figure. . . . . . . .
If the terrain is such that when the axle assembly swings in the directional turning process and the unlocked outside axle is allowed to accelerate ahead of the ring gear, that the inside tire should lose traction (slip) and will accelerate in the distance as traveled by the outside axle, even if this may be immediate and minute, at which point when caught-up, the outside axle will re-lock-up because it won't allow the ring gear to surpass it, then under low to moderate throttle load, just that as required to force movement, this axle will be traveling at the vehicles' distance being covered (in its' relative position) and with both tires turning equally in revolution as being locked together, the inside tire will continue to displace/shovel sod as it goes along. ;)
This is why the farmer unlocks the differential in his tractor at the end of the plowed row (after lifting the plow) so as to turn without digging-up the field. ::)
And this is definitely a disadvantage of "lockers" on truly slippery surfaces (i.g. wet or icy, hard surface roads), as tire "slip" or tire tread "walk" upon the tractive surface is where the "differential" effect takes place and is the inevitable result when the system is being tested. :o
Scott.
My daily driver is a 1990 F250 2wd, 7.3L IDI diesel, with the Sterling 10.25" rear end and a Yukon Grizzly locking differential (The Yukon version of a Detroit Locker)
I have over 100,000 miles using this Yukon Grizzly in all weather, and most off road, driving conditions.
In your scenario a Detroit Locker would stay locked because of the torque applied from the engine, as it works to move the vehicle, will keep the locker locked.
The differential action of a Detroit Locker only happens when the torque forces are low, otherwise that differential will remain locked due to its ratcheting style design.
A Detroit Locker is locked the vast majority of the time by design because it remains locked until the correct low torque conditions allow it to unlock.
In order to turn the truck, physics dictate the front tires must overcome the forward driving forces pushing the truck and trailer forward... in this case both rear tires.
In your scenario four things can happen.
1) Both rear tires break loose because they do not have enough traction to overcome the load... You are stuck until better traction is achieved.
2) Both rear tires have enough traction to cause understeer/push, and your truck does not turn as effectively as it otherwise would... but you are moving.
3) Both rear tires are receiving power, but slipping somewhat, causing oversteer/fishtail... The rear end steps out some, but you are moving.
4) Both rear tires get traction, and the front tires have enough traction, and you drive away without issue.
Based on your description, and example, you do not fully understand the way a Detroit Locker works in a vehicle.... which is pretty common, so you are in a normal place.
. . . . . . .you do not fully understand the way a Detroit Locker works in a vehicle.... which is pretty common, so you are in a normal place.
I believe you may fall into the same "normal place". ???
Yes, it 'is' of a geared "ratchet" design, and though it does 'transfer' torque as produced from the engine through to the axle shafts, it isn't "torque" sensing in it's operation, rather it is simply "speed" sensing, maybe add "position" sensitive. Remember it's just a "ratchet" system, where as the ring gear turns the differential housing it's bolted to, the internal gearing doesn't allow either output side gear, and therefore axle, from not turning at least at this speed; but the ratchet feature allows either to turn faster. So, when traversing a turn, as there is distance differential to be covered, the inside wheel will not be allowed to turn slower in the pivoting maneuver, so it will be the outer wheel in the turn that will "unlock" or "ratchet" forward and accelerate, as being pushed, in order to traverse this greater distance within the same period of time. After the vehicle straightens out, then as soon as the gear sets realign, the disengaged axle re-locks-up, due simply to the side-springs who's pressure which was overcome to allow the ratcheting effect push things back into this position.
One may garner the impression of "torque" sensing because in an instance where the unit is unlocked, when enough torque from the engine is applied to cause the one engaged tire to begin to slip, the unit will catch the slower in motion tire (sometimes with an announcement! ::) ) in lockup. But this action was not based on torque, other than that which caused one tire to turn at a faster rate than the other, rather solely by the fact that as the one tire lost traction the ring gear (an associated componentry) sped up and the planted tire resisted, at least momentarily.
Now once the two tires are spinning, trowing dirt & mud, the unit generally remains locked to both axles, but again this is solely because neither is allowed to be turning at a rate anything less than that of the ring gear, even if this is faster than the overall vehicle's movement; and though torque is what is causing the tires to spin, the unit doesn't care about torque, it's about speed differentials and positioning relationships. ;)
Scott.
My2 cents worth...I had one in a mustang with a stick and one with a c-6. On the street, the stick would have an occasional "slip feeling" going around a 90 degree turn at slow speed. With the automatic, it was barely noticeable. +2 on putting it in and forgetting about it. They are bulletproof. Just one less thing to worry about breaking on your hot rod.
Scott.
I understand, and thanks for the clarification because I did say it wrong.
My statement it likely worded poorly because I am trying to explain that the locker can be engaged, disengaged, readily with proper use of the throttle.
No throttle, or very light throttle, and the differential will run open around corners.
Careful application of the throttle and it can be either open, or locked, depending on your throttle application. (this can lead to some of the driving oddities talked about)
A bit too much throttle, which is easy with a diesel (even a marshmallow of a diesel like my old non-turbo version) making max torque around 1,400 rpm, and the locker is locked, even going around tight corners, as long as the throttle is applying enough torque it will stay locked too.
In the end the point is, beyond a little noise and some driving quirks that are easy to deal with and learn, there is no locking differential that will provide more durability, or consistent locking of the drive wheels than a Detroit Locker.
