FE Power Forums => Private Classifieds => Topic started by: TurboChris on May 29, 2026, 11:00:11 AM
Yesterday a Earl Wade built SOHC was listed on Bring a Trailer
https://bringatrailer.com/listing/engine-279/
Earl Wade Racing Engines completed the build of this 427ci SOHC “Cammer” V8 in October 2009, and the seller notes that it was installed in a car that was used for local car shows and parades for around 1,000 miles before it was removed in February 2026 and placed on a test stand built by the seller. It was conveyed to the seller that the block, crankshaft, pistons, and rings were unused period parts, and the cylinder heads and camshafts were removed from crate engines. Dual carburetors, Eagle H-beam connecting rods, ARP 2000 rod bolts, stainless-steel valves, timing gears, a stub shaft, an upgraded timing chain, and reproduction valve covers were also added during the build. The seller acquired the engine in February 2026 and replaced the alternator and starter. This SOHC V8 is offered in Hamshire, Texas.
(https://i.postimg.cc/ZBn8xCHk/Earl-Wade-cammer.webp) (https://postimg.cc/ZBn8xCHk)
