FE Power Forums => Non-FE Discussion Forum => Topic started by: hbstang on April 16, 2026, 11:58:36 AM
i just changed out my water pump after 92,000 miles and installed an after market one and now its leaking out the weep hole.
any suggestion?this is one from local auto parts store s new chinesium junk .
The pump is bad. The seal is leaking and it isn't going to stop. You need a new pump.
so it turns out that the seal in upper radiator hose was leaking.glad i check before taking apart.
Good...
