FE Power Forums => FE Technical Forum => Topic started by: Dr Mabuse on February 18, 2026, 06:55:34 PM
Title: 1974 Ford 427ci Pre-Chamber Experimental V8
Post by: Dr Mabuse on February 18, 2026, 06:55:34 PM
Engine no. XE626-414-1-15
In the 1970's, American car makers were looking for ways to maintain performance while trying to build economy. Ford was at the forefront of coming up with new avenues to pursue these end goals and the Pre-Chamber engine was one of those products that was created and tested, then quietly put to rest.
The Pre-Chamber engine was based on the 427ci "Wedge" V8 block, but everything else was unique. According to our consignor, this was effectively a 5-stroke engine. Starting with the compression stroke this and the next two strokes were the same as a conventional 4-stroke engine: Compression, Ignition-Power and Exhaust. Difference was that a small jet of distilled water would be sprayed onto the top of the hot piston, which would turn to steam and act as a power-assist while also bringing in a fuel-air mixture during the intake stroke. To date we have not been able to find any test results or public records about this motor.
Our consignor says he believe that as many as 50 of these engines were created for testing. This particular example had been sent for Ford's "X-Garage" at Watkins Glen in upstate New York. After its testing was completed it was most likely scheduled to be destroyed. This engine was acquired from the estate of Mr. Henderson of El Mira, New York, who had been an engineer at the testing facilities of Ford's "X-Garage". As with a number of items sent for testing, on occasion an item might be set aside to be disposed of and eventually was forgotten and written off. Such is the case of this unique engine.
Our consignor related this story to us: "This engine was manufacturer around 1971-2. I acquired this one and a turbocharged version in the mid 1990's. I loaned them to a friend who was going to restored them. However, he lost his shop and before I could get to them, the turbocharged version was sold for scrap in the late 1990's. This engine had been pretty badly abused including the carburetor which is why it is still like that today."
Our inspection showed a number of components with casting numbers carrying a prefix of "XE" which is understood to mean "Experimental Engineering". There are no exhaust ports out the sides of the engines, but there is an outlet at the rear of the engine under the intake manifold. This is a very interesting powerplant and could well be the only survivor of one of Ford's "Better Ideas" that just didn't cut the mustard.
https://cars.bonhams.com/auction/25220/lot/187/1974-ford-427ci-pre-chamber-experimental-v8-engine-no-xe626-414-1-15/
Title: Re: 1974 Ford 427ci Pre-Chamber Experimental V8
Post by: Urgefor on February 19, 2026, 01:19:18 AM
Very interesting.  The block looks to be one of the 385 series (429/460) versus an FE.
Post by: johncroft on February 19, 2026, 06:47:41 AM
With the fuel pump bolts vertical and the integrate timing cover, it looks more like a 335 series engine. 351C/351M/400 type.
Post by: 428kidd on February 19, 2026, 08:22:43 AM
Based off of 351  400M .
Post by: Phil Brown on February 19, 2026, 12:31:23 PM
Can you imagen changing the plugs on that thing when it's in a car   :)
Post by: FrozenMerc on February 19, 2026, 12:53:12 PM
I would love to see some engineering drawings or section cuts of the cylinder heads.  "Pre-Chamber" makes me think of IDI diesels and the Riccardo style combustion chamber, which obviously was fairly effective and millions were built.  I am not sure if this engine uses a similar setup, or something completely different.
Post by: cleandan on March 13, 2026, 09:51:19 AM
With the plugs being like they are I would imagine changing them from below would be relatively easy... from on top, not so much.
Post by: pbf777 on March 13, 2026, 01:08:57 PM
We have not been able to find any test results or public records about this motor.
    I feel that there seems to be a lot of supposition in the scenario as painted above.   :-\
   So . . . . . What happens if somewhere down the road a "Suit" representing Ford Motor Co. shows up at your front door and says:  "We understand that you have property that belongs to us; we never sold that property, one day it just went missing . . . . . and "we" would like it back!    :o
   I suppose you could bellow that "possession is 9/10ths of the law", but then the other side of the coin might be something about "being in possession of stolen property"!  Hmm . . . . . .  ::)
   Scott.
