FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: My427stang on February 16, 2026, 03:11:22 AM
Title: Bullock's Power Service - 489 TFS FE 629 HP/660 TQ
Post by: My427stang on February 16, 2026, 03:11:22 AM
This one is a nice one, it did everything well.  The TFS worked great on the big bore.   Built for a C-6 street combo with power brakes and a shaker.
Here's one of the dyno runs, came on like gangbusters mid-range, video almost doesn't do it justice
https://www.youtube.com/shorts/Yi5Ycj7PnlQ
Performance Summary:
      Cubic Inches:  489            Dyno brand: Stuska
      Power Adder:  N/A             Where dynoed:  Dale Meers Racing, Buffalo, KY
      Peak Horsepower:  629 HP @ 5400 (1 inch Super Sucker for dual plane)
      Peak Torque:  660 @ 4000
Engine Specifications:
   Block brand, material, finished bore size, other notes: BBM 4.28 bore, CnC squared, aligned, torque plate honed
   Crankshaft brand, cast or forged, stroke, journal size: SCAT cast 4.25 internal balance
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  SCAT 6.700 I-beam 7/16 bolt
   Piston brand, material (cast, hypereutectic or forged), dish/dome volume, static CR: Racetec 31 cc 4032
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Clevite rod and main bearings, Durabond cam bearings
   Piston rings brand, size, other notes: Mahle 1.5/1.5/3.0 mm
   Oil Pump, pickup, and drive:  Melling HV, Canton pickup, ARP drive
   Oil pan, windage tray, oil filter adapter:  Canton T-pan, no tray, Ford adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Bullock's Power hydraulic roller, 239 @.050 intake, .620 lift, 115 LSA on 107
   Lifters brand, type:  Morel standard travel
   Timing chain and timing cover: Cloyes 9-position roller, Ford cover
   Cylinder heads brand, material, port and chamber information:  Trick Flow 1.55 spring, blueprinted, Manley seals, no porting
   Valve springs: Trick Flow, 160 seat, 400 open
   Rocker arm brand, type (adjustable or non-adj), material, ratio: Harland Sharp bushed
   Rocker shafts and stands, brand, material:  Harland Sharp
   Pushrods brand, type, length:  Custom Smith Brothers 5/16, .116 wall call/cup non-oiling
   Valve covers, brand, type:   Chrome PBF repop
   Distributor brand, advance curve information:  Factory CJ "Tasca Curve"
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):   CVF aluminum - electric powered on dyno
   Intake manifold brand, material, porting information:  Blue Thunder dual plane - no porting, carb pad dropped .340
   Carburetor(s) brand, type: HR780VS Quick Fuel
   Exhaust manifolds or headers brand, type:  Dyno headers
Title: Re: Bullock's Power Service - 489 TFS FE 629 HP/660 TQ
Post by: mbrunson427 on February 16, 2026, 11:44:52 AM
Out of all the TFS builds, I think this produces the most torque I have seen. Most of them seem to be in the 600-630 range.
Post by: My427stang on February 16, 2026, 12:12:06 PM
It sure liked the BT intake and super sucker!
Post by: Stangman on February 16, 2026, 07:32:46 PM
Ya know I like how a lot of your motors are making substantial horsepower and on this one especially gobs of torque with a fairly mild camshaft.
Post by: 69ramair on February 16, 2026, 11:04:16 PM
Awesome build , excellent power and torque down low
Post by: 6667fan on February 17, 2026, 09:48:27 AM
I think Ross has a thing for 489s.
Post by: My427stang on February 17, 2026, 11:18:49 AM
They tend to find their way to me :)   However, the next four will be 347 SBF, then 496, 505, and 511 FEs,  A couple of 390s may sneak in there too.
I'll post later on the dyno partner that we ran just before this one, very different purpose and unique combo but too cool for school too.
