FE Power Forums => Private Classifieds => Topic started by: BlueDemonMuchoPower on February 09, 2026, 04:59:39 PM
Selling components from a strong running Ford FE solid roller combination that was removed years ago and stored indoors. I originally planned to reuse these parts but decided not to rebuild the engine.
These are not stock take-off parts, these were part of a serious 428 performance engine.
- Ported FE Cylinder Heads - C7AE-A. $450 Heavily ported, 2.16 intake valves and 1.6 exhaust valves, performance springs, machined for high performance use. Has a small crack (see photos) in a head bolt boss, just in the outer edge, repairable, it doesn't extend to the deck surface or combustion area.
- Shaft Rocker System $500 Genuine Ford Power Parts (FPP) shaft-mounted roller rockers. Oiled. One rocker is a different brand but same ratio and never caused issues. They all roll smooth.
- Crower Solid Roller Lifters - $450 solid roller lifters, .875 diam. Tie-bar design, stored oiled indoors, all roll smoothly.
- Mallory Ignition - $150 Mallory Comp 9000 distributor unilite breakerless ignition and HyFire IVA Ignition Box, unable to test but removed working.
Everything is located in San Diego, CA. I can ship anywhere in the U.S. at buyers expense.
Maybe I’m looking at it wrong but the cracked part of the heads is the head bolt hole not the pedestal pad.
Stangman I think you are right, I corrected the post.
