FE Power Forums => Private Classifieds => Topic started by: FirstEliminator on February 08, 2026, 10:23:35 PM
Hi,
A few years ago I obtained a 428 block that is 40 over. Had some use, but not too bad. My machinist honed the cylinders to .045 to get them cleaned up. About a month ago, I ordered a set of custom .045 pistons to go with a 4.125 crank. What I realized yesterday is I already had the custom pistons from a few years ago and forgot about them. The best way to remedy the situation will be to find another 428 block. A block that is already 40 or 30 would be preferred. It would be silly to take a standard bore block out to 45 just to accommodate the extra set of pistons.
Anyone have a 428 block collecting dust?
thanks,
Mark
Dang i just sold one Mark!
Awww.... Oh well. Hopefully there is another out there. I have access to 2 428 standard bore blocks locally, but taking a standard right to 45 is grounds for dismissal.
If I couldn't get a .030 plus block i would consider the std block and sell the pistons you have .
i have a FRESH .040. decked bored and honed with new freeze plugs and cam bearings. was std bore but had to bore .040 to clean up. "A" scratch. 6J8.
.....The best way to remedy the situation will be to find another 428 block. A block that is already 40 or 30 would be preferred. It would be silly to take a standard bore block out to 45 just to accommodate the extra set of pistons. thanks, Mark
I guess one of the ways to gauge whether someone is a real FE guy is when his solution to discovering an extra set of pistons is building another engine instead of selling the pistons. ;)
Best,
Kelly
I see no harm in having an extra stroker FE hanging around.
Best,
Kelly
agree
