FE Power Forums => Non-FE Discussion Forum => Topic started by: 428 GALAXIE on December 31, 2025, 04:21:15 PM
Title: 3d models
Post by: 428 GALAXIE on December 31, 2025, 04:21:15 PM
This is kinda long project but no one happens to have 3d models from: 8-71 blower, fe timing cover and fe block. I totally understand if someone dont want share their work.
Friend has a scan device, if i go that route is there demand for factory block scan. I can make basic 3d model but details are kind of pain so scanned model would be easier.
Title: Re: 3d models
Post by: FrozenMerc on January 05, 2026, 03:08:44 PM
Scanners do not create a 3D model.  Typically they just create point clouds that can be used to generate a 3D CAD model, which can still be a ton of work.  That said, I would love to have an accurate 3D CAD model of an FE block, and an MEL, and a Y-Block....
Post by: 428 GALAXIE on January 06, 2026, 12:21:54 AM
Thanks for the clarifixation, havent messed with scanned models. Scanned something just dor fun couple years back. I'll have to chat with my friend, but I'll probably just make very simplified model for my needs.
Post by: FrozenMerc on January 06, 2026, 01:27:46 PM
Yeah, it is a common misconception.  There are software packages that can take the scanned data and create a non-parametric 3D CAD models of fairly simple geometries, but they are very expensive, require a very clean scan, and still only produce a model that is difficult to manipulate any further.  The industry is getting better, but there is still a long way to go.  I have been playing with 3D scanners for about the past 10 years at various jobs.  Normally get a phone call once or twice a year from a sales rep for Keyence, Faro, or someone else promising me that their latest gadget is the greatest thing since sliced bread, I will have 3D CAD models in 2 minutes, blah, blah, blah.  I invite them in for a demo, and typically I set a compressor housing off a turbo on the table and ask them to generate a model of the involute volume.  Of course they can't because the scanners require line-of-sight and I would have to section the housing along multiple planes, take multiple scans of each section, stitch the scans together, and then import the scan geometry into CAD and use it as a guide to build a proper parametric CAD model.  If the rep gets snotty, I ask them to scan the DT-466 display model we have in the lobby.  "Well you have to disassemble it first..." In the end, the 6 figure price tag just doesn't justify the results.  They are good for resolving simple external geometries, mounting faces, and hole patterns. Complex castings and assemblies, the technology just isn't there yet.
Post by: RustyCrankshaft on January 08, 2026, 10:38:20 PM
No help for the 8-71 or the other castings, but I did just recently scan and build a surface model for the quarter panels on 65 Comet's (hardtop). So if anyone needs re-pop quarters or patch panels I have the data for them. Currently having some patches made for my project. The 3d scanning and surface modeling works pretty decent for this type of use, but it is time consuming depending on the shapes involved. The body lines on the quarter that gradually taper out to flat were a bit tuff to build the model for.
Post by: CDXXVII on January 11, 2026, 08:52:43 AM
Looks good. How do you get from scan to metal? Are you making wood bucks?
Post by: 428 GALAXIE on January 13, 2026, 02:11:09 PM
Definitely cool.
I talked with my friend about scanning and what I can do with them. He will send me couple of samples so I can test how to handle those 3d scans.
If i can handle those scan models we most likely do scans from block, (cylinder head), timing cover and blower manifold. This may take a while.
Post by: RustyCrankshaft on January 22, 2026, 01:12:27 AM
There are 2 ways I've gotten to finished metal. I've 3d printed bucks based off the scan data before. The issue with can be size, if you are trying to do a large panel the 3d printed bucks don't hold up quite as well without some steel backers and I don't have a press big enough to do a large panel.
For the Comet I'm trying out a new process that uses a CNC metal shaper that slowly forms the panel by running a stylus over the panel to gently press the panel into shape. It's not real common for automotive applications yet so it's a little spendy. I could 3d print bucks for a LOT cheaper, but I wanted to try this at least once and see how it goes.
Post by: CDXXVII on January 24, 2026, 09:00:25 AM
Got to be a big 3D printer I imagine. Did the printed buck have openings so you could check the workpiece from the back?
I have seen video of the CNC sheet metal forming. Pretty amazing.
Post by: RustyCrankshaft on January 27, 2026, 12:42:30 AM
I don't have a large 3D printer so I'm limited in the size of buck I can make. Besides, if you get real carried away the printed buck can't take the pressure trying to form a large section anyway. At least not with what's available to me. I print solid pieces. If you need to check it takes 30 seconds to unclamp it.
There are all sorts of ways to do this, but if you over-complicate it then the value starts to disappear in a hurry. In all honesty, for the amount of time I've got into this and what I actually NEED to repair, I could have hand formed the panels in about the same amount of time. But I wanted to try the sheet metal forming and I can see where there would be times that it's just not practical to hand form even if it is possible.
