FE Power Forums => FE Technical Forum => Topic started by: jayb on November 20, 2025, 09:02:30 AM
Performance Automatics used to make these, but apparently they have stopped. As a result these bellhousings are now extremely difficult to find. I've toyed with the idea of tooling up to make these myself, but I am pretty well buried in my existing projects. One of my customers has found a company who may be interested in doing this, JW Performance transmission in Florida. Apparently they already make bellhousings, and could tool up for these but haven't decided whether to go ahead with it. This post is designed to get an idea of how many people would be interested in one of these if they became available in limited quantities.
If we approach this company and they don't want to do it, I might be interested in taking up the project when my work load lightens up a bit. For anyone who doesn't know, foundry tooling for such a project is going to be expensive, in excess of $15K, so if I were going to do it I would need deposits from potential customers. Then, as usually happens, it takes a long time to make the tooling, cast the prototypes, write the machining programs, finish the prototypes, test, etc. before production can start. So for me anyway, this is 1-2 years away.
If this post generates a bunch of positive responses I will contact this company and direct them here for information on interest in the parts. Thanks, Jay
Did you check Quicktime? They used to have an FE/C4 bell.
The one we have on our race car came through QuickTime. They hadn't produced a batch in a while, but I'm sure if they saw a demand stacking up they would go ahead and make another batch. I would try and call Joel's on Joy transmission and see what he knows about that. I would venture to guess that he's the top buyer of those bellhousings.
I wonder if one could approach PA about purchasing their design/ tooling, and what their response would be? If they were getting enough interest in purchases, they would probably still be making them. The JPT unit it probably a dead horse considering the bad road the new owner took the company down
The PA bells that I've used were cast aluminum I think. The Quicktime bells are steel.
RM-9056 would be FE to C4.
They are discontinued, I just checked.
I did not know that these were no longer 'readily' available, so I think there's definitely a market.
I've got a couple pan fill C4 cores that I've been sitting on for potential future service, so I'd probably be a buyer. There have been too many instances (like this one...) of me waiting out on buying something until 'the right time' only to find out that when that time comes what I was waiting to buy is no longer manufactured and impossible to find.
Been down this road before. Foundry tooling is typically specific to the foundry. I have $14K in foundry valve cover tooling for my cast pentroof valve covers, but the foundry I was using went out of business and after checking over a dozen foundries I have not found one that can use the tooling. I wouldn't buy someone else's tooling unless I could find out where it was cast, and with the way most foundries treat small businesses (again from personal experience), I wouldn't want to go that route without a lot of guarantees...
A long time ago I learned from an experienced gentleman that when it comes to small market items, employ the principal of "scarfology". When you see something that you might need someday, and it is available now, scarf it up!
I believe the proper terminology for the "I might need that someday" mentality is called Hoarding. ;D
Intakes and valve covers used to be everywhere at swapmeets. Now you can hardly find them. Then I see guys with entire walls and shelves full of them, but ask to buy one and you get the "I might need that someday"....or the price is exorbitant because they know the hoarders have them all.
But it's not hoarding if your stuff is cool 8)
would it be easier and cheaper to make adapter plates?most that i see now are more than $1,000.
I know Browell will make you dang near anything you're looking for. Has to be closely coordinated and really have to know dimensions.
I personally have a goal of making a FE to TH400 adapter. There's so many more options there and less expensive. If I were to pick off a bellhousing project, I'd lean towards making a TH400 rather than a C4.
Mike, ATI made an adapter plate for the FE to C4 bellhousing that would allow their Powerglide and Turbo 400 transmissions to fit. I have a couple of those, and have thought about duplicating them in the past. If the FE to C4 bell comes back, I will probably make up a few of them. However, they are specific to ATI's transmissions, not a factory turbo 400, and use the ears on the SFI case of their transmission as the attachment points.
Take a look at this..... Judging by the pictures, quality looks kind of shotty.
https://www.speedmaster79.com/Chevy-GM-Turbo-TH400-Steel-Bellhousing?gad_source=1&gad_campaignid=22502494697&gbraid=0AAAAA9pckgK_gMC7eyRus10QgiJjiR5mw&gclid=Cj0KCQiAoZDJBhC0ARIsAERP-F8sqVbo-gC9Fp69gsiiYW4y3lcUeMsYJk3HeZIlOqEx-gA1ydfSoAUaAjiWEALw_wcB
Yep, I wouldn't trust that one. For one thing, it's Speedmaster. Another thing to consider is how the bell attached to the front of the transmission. I could be wrong, but it looks like it attaches via the front pump bolts, after the original bell is cut off. A long while back Performance Automatics sold me a Powerglide with an adapter for their C4 bell, but the adapters bolted onto the front pump bolts. After a few passes at the track the front pump started leaking like a sieve. After pulling the trans to repair it, it lasted another month or so before it started leaking again. So I wouldn't go forward with any bell that attaches to the front pump bolts.
I also see that Speedmaster offers a turbo 400 case, with a ring of bolt holes around the outside of the case itself. There are 8 holes in their case. There are 7 holes in the bell in the link. I wonder if they make a bell with the 8 holes to match their case? Not that I would trust that either...
I had a PA FE to c4 Housing purchased thru Jegs that stayed on back order for about one year. They kept pushing the ship date back and finally cancelled my order. Jegs had my money for a year but I wanted the PA bell housing, but never got it. I do have a QuickTime FE to C4 bell housing, but access to the torque convertor looked better on the PA unit
I have a couple of fe aluminum bells that I think came off of cruisomatics could these be adapted to a C4? Does anyone here have any firsthand experience doing this?
Funny how they can manage a SFI with all those bubble gum welds yet you can't get a SFI on a small repair or modification with a professional grade weld.
Yes, people have made them from the older FX/MX Cruise-O-Matic and the later FMX bellhousings.
I did such a modification on my 390 Mustang race car, ran it for several years with 0 problems Jim Kramer
was that powerglide a stock case glide with bell cut off?i have used the c4 jw bell and have not had an issue,but the c4 originally came with a bolt on to pump bell.
That powerglide had an ATI case, and the engine made 900+ HP.
