FE Power Forums => FE Technical Forum => Topic started by: JimNolan on August 29, 2013, 03:08:11 PM
Guys,
I've been shifting at 4800 on my 410 FE. It sort of talks to me at that RPM and says "shift dummy". Should I drop back in rpm for more reasonable outcome in bracket racing. Or, run it till it grunts at 4800. The 410 stock engine had 4600 rpm listed as peak HP. Most of you know my engine so where would you shift. The cam was designed to be shifted at 5000 rpm. Give me some reasoning here.
If you have a cam rated to 5k and proper valve springs for it, it should be fine at 4800. I'm kinda new here so don't know what heads you have, I'm guessing stock? If you're curious to see if it is loosing power at that level, shift it at 44-4500 a pass or two and see how the early numbers compare.
I'll try that. Tomorrow I would like to get a couple runs in anyway after tech. The heads are Edelbrock 428CJ. It's not a wild ass cam by any means 515/540 lift. I idle at 600 rpm smoothly (Cam Research). It breaks loose the 8" Street Pro tires pretty bad. Cast pistons is the reason for the rpm specification. I'll make a couple passes at 4500 rpm and see what happens. Thanks
Your shift point should be set so as to maximize the area under your horsepower curve. Assuming, of course, that the engine is capable of revving that high; some aren't. A good rule of thumb is to shift 500 RPM past the horsepower peak.
I would consider trying different shift points at the track, to see how your ETs stack up in comparison. Fastest ET = best shift point.
One comment, if looking for the quickest ET, except possibly 1st gear, I wouldn't shift any lower than peak HP RPM, and probably 300-400 over than assuming you didn't have any valve float issues.
Sometimes a torquey engine likes to be short shifted out 1-2, but my WAG would be 5200-5400 shift point for the other gears if you are peaking 4900-5100
you want to pay attention to what rpm level you drop to AFTER the shift, try to keep that point still in your max power band.
Thanks guys, I'll try different shift points. I'll take the best of three and see if I can match it. I'll use that for dial. I figure the new "Nostalgia" bracket will be loaded " it's a good payout" and there will be plenty of accomplished drivers there to send me home. Best I can do is "everything the same, every time". I'd like to go farther than my usual three elimination rounds this time.
PS: I carry 6 - 6 1/2 qts of oil with my windage tray and 5qt oil pan also. I should be ready.
when the valves float , SHIFT .....lol ;D
Well, I like to beat my car to death trying to figure out how to drive it Friday. I ended up using 28lbs of air in the rear. Leaving the line with it revved to 2000rpm and shifting at 5000 rpm. By shifting at 5000 I wasn't spending time squealing the tires in second and third. It just went. 14.3 ET @ 98 mph. Everyone was complaining because of the humidity. So, without the humidity I figure I've got a 14.1-14.2 car with street tires. I'm happy. Jim
PS. The temp was 90 something Friday and I ran 5 times ( about 30 minutes apart ) The first run I pulled all the way through the quarter, Second run the same. Third run it fell on it's nose once, Forth run it fell on it's nose about two times, Fifth time it stumbled all the way through forth gear. Came back Saturday and didn't even run during time trials. Threw a dial-in on it, took it down cold for eliminations and it ran great. I bogged coming off line but it pulled great. Let it cool down two hours for my second round of eliminations and it went through really strong again. In fact it was so great that I broke out by .3 seconds. And I had dialed in my best time on Friday.
Well that's good news. And you know your car needs to be cool to run all the way through if it's hot again.
What I've always found to help me determine what makes my cars quickest is to find at what RPM it pulls hardest. I can find out easily in 3rd gear by flooring it at different RPM levels (not using 1st or 2nd for obvious reasons, like tire smoke control, or even 3rd in my Mach :) ), like 3500, 4000, 4500 etc. Then you know that if you shift at the time that will drop the RPMs to that point, the car is going to pull hardest into the next gear. It helps when you don't have ET slips and dyno figures to pin-point exactly what works best.
Great work and it's fun to go round after round and just drive it not work on it.
Quick question gents. I've never drag raced other than as a kid on a remote deadend strip. In other words I've never been a real racer before.
I have a 4 speed top loader. My engine builder told me 6000 rpm was about redline. If I "speed" shift at about 4800 the engine rev will most likely shoot up to the 6k range for a micro second. (of course longer if I miss a gear) Is it super bad for the motor if this happens?
Also, what does valve float feel like while driving?
Still breaking in my motor and clutch until this Spring, but would one day like to take it to the strip in Albuquerque just to see what it will run.
Jim Nolan, I'm curious about your 410 build. I just had one done and I was wondering what hp and torque I might expect from it. Can you tell me what yours has?
thx a ton, Dave J
thx a ton, Dave J
Dave J,
It's not speed shift, it's called power shifting. And, you won't be seeing 6K on your tach. Your engine doesn't have that much time between completely disengaged to engaged again to get there.
As far as my 410 is concerned I designed it to have a .050 quench, 9.5 CR and 7.5 DCR. It was imperative that my engine take me on a 1000 mile road trip, burn 87 octane gas, not overheat in long periods of traffic congestion, idle at 650rpm and give somewhat decent gas mileage yet make me think I was driving a 60's muscle car. I achieved all that. I estimate the engine to be delivering about 375 horsepower. DesktopDyno5 says I've got 416 HP @5000 rpm and 474 lbs torque at 4000 rpm ( I don't believe it ). I haven't got tires that will hook up to find out how fast through the quarter mile it really is. It is without doubt a high 13's car if I could break the 2.1 sec 60' mark. If I were you, I'd limit my RPM's to 4800. After everything is said and done you want to be able to use it again. It's still a high torque engine. Not a short stroke chevy that has to wind to 7000 rpm just to get HP out of it. A somewhat stock FE gets it's HP below 5000 rpm. For my engine I like 5000 rpm shifts just because my rpm's don't drop back far enough to overtorque the rear wheels and make them spin so much in 2nd and 3rd. It's a smooth ride once you get past the 60' mark. Good luck.
PS. You asked about valve float. I used to float the valves on my 66 Fairlane GT all the time in high gear. The car will just stop pulling, start maintaining a constant speed and if you look out the back window you won't be able to see behind you because of all the blue smoke. Most performance hydraulic lifters will last to 5000 rpm. You need solid lifters after that. And, don't be misled as to what rpm your engine will go to. A fully blown 650 HP engine is a lot different than a hopped up 375 HP more stock engine. If you look at your manufacture's specifications it'll tell you what to look for in the way of torque and horsepower. The biggest difference between a race engine and a hopped up engine is you can drive farther than a 1/4 mile with a hopped up engine. lol
I have a data recorder that I use occasionally (I would use it all the time if I could, but the class I race does not allow it... so it is disabled). When I ran my old 428 and Toploader, I recorded some runs with it. I "power shifted" it and shifted at 6500 RPM, the engine spiked up to 6800, before coming down to 5100 for the bottom of the next gear. You can see that clearly with the charts. I could shift pretty fast with the "crash box" Toploader and super shifter3, but not as fast as the Jerico with Long verti-gate shifter I run now. I am sure the HP level also matters, as more power will spike higher.. and quicker, than with less power. The 428 had less than 600 HP and at 3580# would run around 10.50@128. My current 427 stroker combo is 7 tenths and 10 MPH faster, but no data as I was in "bracket mode" running for points.
I would drive it like you stole it. Have a working rev limiter, and shift it as high as you dare. If you have a self-imposed 6000 rev limit, shift a few hundred before that. My own engine never sees less than 5100 on a pass from launch to lights, and I know several FE guys that run higher RPM than me, some a lot higher. It all depends on the combo of course, the sum of parts etc. and/or weakest link...
I turned 7700 a couple times last year, not by choice... oops, didn't break anything though... in the engine.
Combination !!!
I used to help a guy who ran 455 Olds 442 back in 1968 we twisted the snot out of that thing. 25 years later 5400 max and runs quicker and more MPH.
I guess we got smarter along the way LOL.
Thx gents, all great info.
I think mine is fairly similar to yours Jim. I told the builder it was just for fun, and that I wanted a tire spinning street car. It's just a fun Ratrod type T-bird that I cut a hole in the floor for a 4 speed. I fell in love with the idea of a 390 with a longer stroke after reading a bunch of stuff on the interweb. They all say torque is what'll move a heavy car. The builder told me that it was basically a 66, 67 Merc 410. It was bored .030. Has c4ae heads with CJ exhaust valves (stainless steel) and comp springs. I didn't know anything about "shimming" so I asked the builder after I read it on the build specs. He said something like it makes all the valves perform the same (evenly) and will help stop valve float. He used a CJ cam. It idles OK at 650 rpm. The CR is 10.5 and runs fine on 91 octane. I had found an RPM Performer intake. I put a Edel 750 with the appropriate jets and metering rods for our altitude. I also have FPA headers, they are the only ones I could find for a 59 T-bird - they were pricey but really well made. He said it would probably be in the 375 to 400 hp range and torque would be in the 450 range. The car weighs 3800 without me.
What does .050 quench and 7.5 DCR mean? Also, what is desktop dyno? I'm guessing that's software for estimation purposes?
My rearend is a 3.89 one wheel turner. Once I break in the motor and clutch I will see how the wheel spins and hopefully get a limited slip 3.50 to 3.70ish pumpkin. I want to be able to drive it 90 miles to Albuquerque sometimes. I might buy a used trailer and tow it. If I do I'll go with a lower rearend.
I had a hard time setting the timing and I'm still tuning it. The builder told me the timing should be about 10-12 and that it should never go over 38 total. I think I might start a whole new thread on that when I get some warmer outdoor temperatures and can work on it.
thx, Dave J
thx, Dave J
Dave J,
You need to figure out first what you want your car to do. With a four speed transmission you have to make a choice. When I restored my 57 Fairlane the first thing I did was design it. I wanted drag racing fun AND touring economy and smoothness. That's why I went with a Tremec TKO 600 with a 3.50 Tru-Trac. I cruise at 65mph and 1850 rpm getting 16 mpg and I can't put big enough tires under my car to keep it from spinning when I get on it. My advice to you with a 4 speed is to make a choice. Since I enjoy driving my car and going on trips I'd choose a 3.25 rear gear ratio at the most. But, if you like cruising down the interstate with your engine turning 3000 rpm, go with a lower gear.
Quench: That's the distance between the top of the piston and the bottom of the head with the head gaskets installed. You can go down to .040 at a minimum and .050 at the most to achieve a more complete gas atomization that will enhance the combustion in the cylinder and lower your needed octane level per compression ratio used. In other words it will help minimize spark knock when using lower octane fuels with higher compression engines.
DCR: Dynamic Compression Ratio is the actual compression ratio the engine sees. You need to look this up on the internet to fully understand it but in summary it's the compression ratio with stroke measured after the valves are fully closed on the compression stroke.
On both my 406 and 410 the Quench and DCR were designed into the engine before the cam, pistons or head gaskets were chosen. That's why I can burn 87 octane with a 10.5 CR, .042 Quench , 7.6 DCR 406ci engine and a 9.5 CR, .050 Quench, 7.5 DCR 410 ci engine.
Timing: My 410 ci engine has an initial timing of 14 degrees and a total of 38 degrees. The 406 ci had to be set at 17 degrees initial with a total of 34 degrees. The 406 had to have an ignition system that retarded the timing 5 degrees to enable the use of a stock starter though. You can't start a FE engine at 17 degrees, not very well anyway. I hope this helps.
PS The 406 engine was initially designed to drag race. I built the engine before I got the car from New Mexico. The car ended up being too nice to cut up so I changed the ring and pinion in the 3.50 Tru-Trac I'd previously bought to a 2.75 gear ratio. I also had to change the cam in the engine and turn the vacuum screw back in the Jay Broader transmission so it wouldn't jerk your head off during slow speed shifts. I get 14 mpg with that engine and I cruise at 2150 rpm at 65mph. I had to make a choice with that car because I didn't have a transmission versatile enough for touring and drag racing. I can barely spin a wheel with that car (406).
Thx again Jim,
As for my car I guess the end project in my head is something like you described with your 57 Fairlane. However I don't care about gas mileage just as long as I can run it on pump gas. I'm not going to put more than 300-500 miles on it each year so the $ in gas won't be that big of a deal. Doug Anderson in Albuquerque was the builder. I told him that, and I also told him I wanted a fairly rowdy cam, but he suggested I keep the cam calm enough to give me vacuum for the front disc brakes. Doug is an old FE guy through and through. Bn69stang tells me that Doug owns an original T bolt. I told him basically what I wanted it to be, but I'd like his recommendations.
My plan for the car was a retirement project in 4 years. However I started playing around with it in my spare time and now I'm having too much fun to quit! With that, I decided to make it run and then do upgrades here and there as money and time permits. I started with an unknown 390 out of a 67 LTD. Got that running and drove it some throughout the summer but I fried the clutch and decided to have Anderson's shop build my motor. Next will be the rear end, after that some head work, then the Tremec most likely, but all that will be over a few years time. For the next 12 months I'll have to deal with 55 mph at 2500 rpm on the interstate if I decide to take it anywhere. The body and interior will be original patina by father time and mother nature.
If you're bored or interested in a very amateur project you check out pictures and descriptions at this link.
https://picasaweb.google.com/101492851059660555641/StreetRatProject?authkey=Gv1sRgCJSKjNbR6eunsgE
thx again, Dave J
When the fender starts to lay down - SHIFT! (http://board.moparts.org/ubbthreads/images/graemlins/drive.gif)
If you have the torque to pull the load, the sooner you shift the quicker it will be--if not, then you need the horsepower to pull you, and then you need to go past the recommended rpm of the camshaft by 200-300rpm, but not let the engine pull down below the torque band on gear changes. Sounds simple, but it tough to actually do. Another way is to gear the car so that it maxes out the rpm just at the stripe. Joe-JDC
Thx Joe, the idea behind this motor was to have the best of both worlds. Some articles I read said that an FE can have the torque at lower rpm and hp at higher rpm. That's what I told the builder I was hoping for.
Something I didn't know, (because I only started looking at, and understanding cams) is that my cam is a Lunati CJ. It has more duration than a stock CJ cam. It's range is stated as 3000-6000. I'll have to finish breaking in the clutch and motor before this spring and then find a nice quiet road to do some test driving.
I'll also look on line and see what I can learn about a rev limiter. I know nothing about them but I think I know what they do.
Appreciate all the input!
Dave J
