FE Power Forums => FE Technical Forum => Topic started by: Royce on May 24, 2025, 07:45:39 AM
Title: Mallory distributor gear
Post by: Royce on May 24, 2025, 07:45:39 AM
I am putting an FE into an RCR GT40. It's a tight squeeze. No room for water pump and the MSD or even stock Ford distributor will not work  My only option seems to be an older Mallory with a marine crab cap.. The FE has a roller cam. What  gear would I use . It's a YL/25 Mallory distributor..
Title: Re: Mallory distributor gear
Post by: blykins on May 24, 2025, 07:50:44 AM
What's the shaft diameter, Royce?  You need a steel gear.  They're available in .467" and .531".
Post by: pbf777 on May 24, 2025, 03:20:07 PM
   Maybe even .500"?   :-\
   Scott.
Post by: philminotti on May 25, 2025, 03:32:37 PM
Hi Royce
Not to change the topic, but what transaxle are you gonna use?
Phil
Post by: Dumpling on May 27, 2025, 11:14:42 PM
Coil packs?
Post by: Barry_R on May 28, 2025, 09:26:01 PM
Mallory is/was .500
Post by: Ford428CJ on June 07, 2025, 09:22:34 AM
I have a couple YL Laying around my shop and I’ll go measure the shaft….
Post by: JumpinJim on June 07, 2025, 10:24:38 AM
My old YL is a 37 series #3755301 and the shaft diameter is .467
I used Crane steel gear #34970-1 (Not available any longer?)
