FE Power Forums => FE Technical Forum => Topic started by: 482supersnake on May 13, 2025, 01:08:47 PM
https://youtu.be/InUvRFvkSgo?si=QlLZyZUpzg3lPwR3
Its basically a 66/67 Fairlane that has had the front and rear sheet metal and dash replaced with Aussie 1972 Falcon GT stuff to make it look like a two door hardtop version of a car that was only ever made as a four door. Front sheet metal is pretty easy whether you cut the chassis off to convert to RHD or not. The rear not so much. Not sure if I like it or not, but it has been done very well.
