FE Power Forums => FE Technical Forum => Topic started by: pkm123 on March 26, 2025, 01:02:53 PM
Title: Rear main seal leak
Post by: pkm123 on March 26, 2025, 01:02:53 PM
Would someone please tell me how best to prevent a rea main seal leak.  I've changed the rear seal once with some improvement and I added a PCV valve, but it's still leaking.  Thanks in advance.
Title: Re: Rear main seal leak
Post by: allrightmike on March 26, 2025, 03:59:09 PM
Find "search" top of page, type rear main leak, lots of info, lots of leaks!
Post by: RustyCrankshaft on March 26, 2025, 07:51:36 PM
Where is it leaking from? The seal itself, the cap? What kind of seal? Couple of things you can try is a different brand seal or maybe one of the one piece seals. Are you using the side seals? If you are I'd probably ditch those. I've had much better luck filling those full of a good quality RTV.
