FE Power Forums => FE Technical Forum => Topic started by: 428Marauder on September 22, 2024, 12:56:11 PM
Title: Thermostat suggestions for 427 in Arizona
Post by: 428Marauder on September 22, 2024, 12:56:11 PM
Hi all,
So, I have a 63 R code Galaxie that I’ve been having trouble with some heat soak on the starter. I’m in the process of going through the cooling system and have the radiator and overflow tank outside of the car now. The thermostat connects to the tank and I could easily replace it. Car used to live in colder Indiana but it’s here in Arizona now. Thoughts?
Title: Re: Thermostat suggestions for 427 in Arizona
Post by: GerryP on September 22, 2024, 06:55:36 PM
A 180 will work just fine.  If the engine has a propensity to overheating, a cooler thermostat won't fix that.  It will only give you a couple more minutes before it does overheat.
Post by: 428Marauder on September 22, 2024, 08:59:12 PM
No, it doesn’t overheat, just the starter heat soak issue. Came apart clean so I’m just going to leave it in there. I’ll have to look up what it is. Someone told me they had the same problem and dialing back the timing solved the problem, which I will try next if this cooling system flush doesn’t do it.
Post by: GerryP on September 23, 2024, 07:46:28 AM
Test the voltage drop between the battery and the starter terminal on the starter.  To do that, you get the system in the circumstance where you get what you call heat soak, then put one end of the multimeter (DC voltage) on the positive side of the battery terminal and the other probe on the starter terminal.  You crank the engine and the value you see on the meter is the voltage reaching the starter.  If it is below battery voltage, you have a problem in you circuit.  Could be corrosion on the cables or in the solenoid.  To test the starter, you need an amp clamp or a high amperage tester to measure the amp draw by the starter.
Post by: 428Marauder on September 23, 2024, 02:18:10 PM
Thanks Gerry,
It’s got a brand new RobbMc 3001 in it, so the starter should be good. New starter cable also. Could be somewhere else in the circuit though.
Post by: jmlay on September 23, 2024, 02:54:09 PM
If you have not already, verify ground as well.
Post by: GerryP on September 23, 2024, 05:27:47 PM
Thanks Gerry,
I wrote my instructions wrong.  What you see on the meter is the actual voltage loss from point to point.  You will not see battery voltage in the voltage drop test.
Post by: Stangman on September 30, 2024, 11:49:31 PM
What is your actual timing that you want to back it off. Do you have any shielding on the cable going down to the starter. The ground is clean I expect meaning no paint in between. Is this a stock build. It might need timing more advanced.
