FE Power Forums => Non-FE Discussion Forum => Topic started by: AlanCasida on August 27, 2024, 11:57:57 AM
As of right now it is looking like I am on Plan C and will be taking my 04' Mach 1 on Raceweek. I have ordered some stock dimension Nitto drag radials and will be replacing the u-joints with Moog solid units. I also ordered a rear cover girdle. My question is do I need to do anything a far as axles while I have the cover off? My car is box stock DOHC 4.6 with a 5 speed and I will most likely launch at a low 1500-2000 rpm. I know very little about 8.8 rear ends and I guess I don't want to be sitting in the pits with a broken axle.
For years, I ran a stock 28 spline/Traction Lok with 3.55 gears in my daily driver/weekend dragstrip car. It was a 78 fairmont, with a warmed over 302 and T5 5 speed, which weighed 3340 pounds with me in it. Over the years, I must have put 500 1/4 mile dragstrip passes on that car, usually with 8 1/2x26-15" slicks. The car ran low 13s, letting the clutch out at 2800-3200 RPM, and I never hurt the 8.8. At least, until I decided to lean on it harder, to try and get a 12 second ET slip, which I did, by launching at 4500 RPM, (12.80 @ 106 MPH), but after a couple of such higher RPM launches, I broke a stock 28 spline axle. Installed another stock axle, and kept racing the car, albeit, at the lower 3000ish launches, and never had any further issues. That said, I imagine a 2004 Mustang is likely at least a couple hundred pounds heavier, but with drag radials, and a much lower launch RPM, I would be surprised if you had any issues, unless you have a real aggressive "Snively Whiplash" type clutch. No idea if the 2004 would have 28 or 31 spline axles, but if they are 31, I would have no concerns. I ran mid 10s in my 85 Mustang, with a 331 SBF and Jerico 4 speed, launching at over 6000 RPM, with Moser 31 spline axles, and never hurt the 31 spline axles.
IIRC, that came stock with the 31 spline axles, and if so, you should not have to worry about them. The clutch will go before they do. We ran a '91 LX with slicks into the 10.75/138mph with 5psi before we broke a 28 spline axle. Slicks are the breaking point for most the 28 spline axle issues. Going to 31 splines solved the issue and were safe well into the 9s. JMO/E Joe-JDC
