FE Power Forums => Non-FE Discussion Forum => Topic started by: cleandan on May 19, 2024, 12:35:39 PM
Title: Who are the current good guys where I can purchase a complete 9" center section?
Post by: cleandan on May 19, 2024, 12:35:39 PM
So much has changed over the last four years....I am wondering who are the current good guys building and selling complete 9" center sections?
I am doing a swap on a 65 Shelby GT350 so I want to keep the original center section intact and original.
It just seems easiest to buy a complete center section for this job...partially due to time constraints too.
I will end up with a 28 spline Detroit Locker (or Eaton Truetrac) 3.25:1 gears and a nice case and pinion carrier.
Who do you know that is providing good customer service, good products, and generally ticking the boxes for a good place to do business with.
I know I can go online and find this stuff, but I'm tired of poop head online businesses, so I'm searching for a good place.
Thanks.
Title: Re: Who are the current good guys where I can purchase a complete 9" center section?
Post by: MeanGene on May 20, 2024, 11:12:39 AM
Try Jay Cushman on FB, he trades in a lot of surplus or used NASCAR stuff. Very high quality stuff, not drag racing type but circle track and road race
Post by: TurboChris on May 21, 2024, 09:01:30 PM
Quick Performance has a good reputation.
https://www.quickperformance.com/Ford-9-Inch-9-Ford_c_37.html?gad_source=1&gclid=Cj0KCQjwjLGyBhCYARIsAPqTz1-EFCdJlIdJiFoAamkRPRH2rYyvPD9hmEsu7t6hEn5OZR7CJwNtfj4aAiWUEALw_wcB
Title: Quick performance
Post by: Jim Comet on May 22, 2024, 05:29:03 AM
Times 2 for Quick performance in IA. I have had them do a couple of gear changes in my Yukon aluminum thru bolt 9 inch. Jim
Post by: CV355 on June 03, 2024, 07:21:17 AM
I went with a full Moser M9, but they also cell just the center sections.
Post by: Drew Pojedinec on June 03, 2024, 05:34:00 PM
I wouldn’t consider buying a used nascar unit when Quick Performance exists.
Post by: Russ67Scode on June 04, 2024, 10:42:37 AM
Times 4 for quick performance.  Just received my third member for my Fairlane. Aluminum STRANGE case
Post by: cjshaker on June 04, 2024, 03:34:40 PM
I'm curious what makes Quick Performance better than buying direct from Strange or Mark Williams directly?
Price?
Service?
Post by: Russ67Scode on June 04, 2024, 07:07:41 PM
YES the price.  was cheaper to have them assemble the third member than to buy from strange
Post by: cleandan on June 10, 2024, 10:51:29 PM
The rear end has been completely taken care of.
I installed an iron N-case, iron daytona carrier, Detroit True Trac, 3.70:1 gears, and a 1350 yolk.
Thanks for all the info.
So far everything is working well.
Post by: AlanCasida on June 16, 2024, 01:08:33 PM
I have bought a couple of the used NASCAR units and my experience was less that favorable. Both units howled and the ones I bought   used the older style Detroit Locker that clacked really loud going around corners. I also suspected the locker had been modified because it semm it unlocked pretty easy.  They also used the 3.25 bearing case which isn't a big deal unless you want to swap in a 28-31 spline true trac or even a later Eaton Detroit soft locker then you need a special adapter breaing race.
