FE Power Forums => Private Classifieds => Topic started by: Dubs1 on May 13, 2024, 10:53:09 AM
FOR SALE
NEW NEVER USED SET OF COMP CAMS FE HYDRAULIC ROLLER SET.
ASKING $450/offer plus shipping
Larry ltduba@hotmail.com (720) 839-3477
Do you have the cam specs/ number?
The specs are as foliows;
gross valve lift INTAKE EXHAUST PART 3 33-000-11 SN # l 0199-16
.600 .622 GRIND # FB 3316r 3317r
DURATION
TAPPET LIFT .006 287 .293
VALVE TIMING OPEN CLOSE
.050 INT 11 BTDC 45 ATDC
107.0 INTAKE CENTERLINE
DURATION @ .050 INTAKE EXHAUST
236 242
LOBE LIFT .3470 .3600
LOBE SEPARETION 112.0
just to clarify things,is this the cam and hydraulic roller lifters both for $450?
