FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: blykins on April 24, 2024, 05:06:02 AM
Title: Lykins Motorsports Ford 465ci Tunnel Port Street Engine
Post by: blykins on April 24, 2024, 05:06:02 AM
Performance Summary:
      Cubic Inches:    465           Dyno brand: Stuska
      Power Adder:    Nope     Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  575 @ 6000
      Peak Torque:  545 lb-ft
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory Ford 427 S/O, hydraulic block
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 9000 series 4.125" stroke
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat I-beam, 6.700
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec, dish, 9.8:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Federal Mogul 125M, Clevite CB743
   Piston rings brand, size, other notes:  Total Seal, 1.5/1.5/3mm
   Oil Pump, pickup, and drive:  Melling M57B
   Oil pan, windage tray, oil filter adapter:  Canton deep front sump, factory style oil filter adapter
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Factory timing cover, Cloyes billet
   Cylinder heads brand, material, port and chamber information:  Factory Tunnel Port, no port work
   Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:  SI stainless, 11/32", 2.250"
   Exhaust valve brand, head size, stem size:  SI stainless, 11/32", 1.750"
   Valve springs brand, part number, specs:
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D street, TP, 1.75
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length: Trend, 5/16", .105"
   Valve covers, brand, type:  Blue Thunder/Holman Moody
   Distributor brand, advance curve information:  Factory FE, Pertronix, locked out
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Factory style replacement
   Intake manifold brand, material, porting information:  Factory TP, 2x4 single plane
   Carburetor(s) brand, type:  Holley 710's, Drew Pojedinec
   Exhaust manifolds or headers brand, type:  Dyno headers
Title: Re: Lykins Motorsports Ford 465ci Tunnel Port Street Engine
Post by: blykins on April 24, 2024, 05:06:21 AM
Another FE, so that everyone doesn't get their feelings hurt.
Post by: Stangman on April 24, 2024, 02:09:54 PM
Ha funny
