FE Power Forums => FE Technical Forum => Topic started by: frnkeore on January 10, 2024, 02:29:27 PM
What is the highest lift anyone has reliably run with these stock rockers?
I'm interested in spring pressures with solid rollers, too.
I have ran factory rockers at .660" lift and 425 lbs of spring load. That was with a rules road race engine with REM/cryo rockers.
No way I'd ever associate a factory rocker with a solid roller.
I ran a 296/.660 Delong solid with Isky 8005-A springs many moons ago
Like some of the others, I have also ran a solid flat tappet cam with factory adjustable rockers, with over .650" lift. t was an old Comp Cam, I believe the exhaust lift was either .678 or .687" lift. That was in the late 70s-early 80s, wasn`t a lot of alternatives back then.Never hurt a rocker arm but did break a few shafts, no end supports back then.
That you, all, I appreciate it.
I've got some Bullet lobes picked out that give a net lift of .688/.704. They are as low as I can get with the duration I want. It's for Jay's TP heads. I'm going to try for 7mm SS valves.
I'm hoping I can use a roller but, I can't afford T&D rockers, that's why I'm asking.
The Isky rockers are quite a bit beefier, and have a hardened tip insert
