FE Power Forums => Vendor Classifieds => Topic started by: blykins on January 09, 2024, 12:05:05 PM
Title: FS: NIB custom Ford FE solid roller camshaft for sale....
Post by: blykins on January 09, 2024, 12:05:05 PM
I had this cam ground for a customer's engine, which is using FE Power heads, but the customer opted to have the heads CNC ported, which affects a lot of the cam specs.  Has been out of the box for inspection only.
Camshaft is 271/284 @ .050", 113 LSA, .426"/.445" lobe lift.  Fairly aggressive lobes that have always made *really good* power for me in the past.  Require a good bit of spring load and/or light valves.  You can contact me to see what the cam would do with your application before buying.
$425 plus shipping.
