FE Power Forums => Private Classifieds => Topic started by: fomocoloco on July 11, 2013, 07:27:18 PM
wanted a front motor mount setup with the cast iron timing chain cover and a horseshoe shaped bracket that bolt on with the timing chain cover. the casting number on the one i want is a c7****. this engine takes a standard water pump. thanks.
I believe I have 2 of these covers and mts I will check the numbers. Both are still on engines that I bought for parts.
In case you need another.
http://www.network54.com/Forum/75943/thread/1379371499/390+blocks
i am looking for another. the casting number on the covers that i desire is C7TE 6059B. thanks.
jim
