FE Power Forums => FE Technical Forum => Topic started by: 62_BattleBird on November 13, 2023, 12:02:44 AM
Title: Please Help! Holley Terminator 2x4 mounting issue
Post by: 62_BattleBird on November 13, 2023, 12:02:44 AM
Ok, please forgive my ignorance here, but as you can see from the pictures the carbs do not fit when mounted sideways (which they have to be due to space). I looked around for some sort of adapter plate or something, and was unable to find anything. I waited 6mo for this to finally come in and now I'm at a complete loss and hope I didn't waste almost $3k. If anyone has any advice at all I'd greatly appreciate it.
Title: Re: Please Help! Holley Terminator 2x4 mounting issue
Post by: Tunnelwedge on November 13, 2023, 06:07:20 AM
These work. Out of stock but if you have a mill they are easy to make.
https://www.edelbrock.com/shop/accessories/carb-adapter-mounts-4150-standard-flange-holley-carbs-sideways-on-tunnel-rams-2694.html
Post by: 1964Fastback on November 13, 2023, 06:33:37 AM
These show as in stock from Offy but 200 bucks.  Don't know if the center rib would cause problems or not.
Pat
https://www.summitracing.com/parts/ofy-5832
Post by: 62_BattleBird on November 13, 2023, 09:58:13 PM
Awesome, thank you. I’ve got it set to notify me when in stock. If the Offy ones don’t work, I’ll give these a try.
Post by: 62_BattleBird on November 13, 2023, 09:59:32 PM
Pat
I just ordered a set and will be picking them up tomorrow (live about 20mi from the Arlington TX location). I figure I could cut out that rib if it interferes. Thanks a ton for the heads up!
Post by: pbf777 on November 14, 2023, 11:00:27 AM
       Apparently the issue is solely the existing bolt spacing when the carb/T.B. are turned 90 degrees/sideways (though there may prove to be linkage issues impacting the plenum crossover/balance passage also?  :-\)?  If so, then yes the 90 degree adapters are an option (check 4V bore positioning & sizing  ;)), but mostly back in the day of doing this we would choose to add material thru heli-arc welding in order to present bosses for the drilling and tapping of the appropriately positioned threaded holes.   :)
       Scott.
       P.S.: I have a Tunnel-Wedge intake with two 850 C.F.M. "Center-Squirters" mounted sideways in this fashion hanging on the wall.  8)
Post by: 62_BattleBird on November 18, 2023, 11:54:53 PM
Well, the Offy solution didn't work as it seems they're simply an adapter to shift the carb back about 1/2in. I also purchased an adapter plate from Alkydigger (https://www.alkydigger.net/product/TBS4300.html) and wasted almost $300 there lol, so it looks like I'm going to have to learn how to make my own adapters. I'll update this thread as I make progress for anyone interested.
Post by: 62_BattleBird on November 19, 2023, 12:00:33 AM
       Scott.
Thanks a ton for the insight. I'm going to learn how to make my own adapters through trial and error (I possess none of the required skill at the moment :) ) as every other off the shelf solution has failed thus far. I just purchased a multi-process welder and a plasma cutter from eastwood and will begin to work on welding technique. I also bought some large sections of 1/2in thick (wanted 1in but it wasn't readily available on amazon) aluminum to practice on. With any luck I'll have a rough draft version of what I need in the next month or so, as I only get a couple hours a week to work on this stuff. Anyway, thanks again for your unique insight and advice!
Post by: TurboChris on November 19, 2023, 12:55:21 AM
Do yourself a BIG favor and pick up a spool gun for welding aluminum. I am also a novice welder and found a couple hundred dollar spool gun allowed me to actually lay down a pretty impressive weld (for a novice) on aluminum.
[/quote]
[/quote]
Post by: Tunnelwedge on November 19, 2023, 06:30:53 AM
I would buy a couple of 1" spacers. The biggest rough cheapo's from Summit.
And start from there.
https://www.summitracing.com/parts/sum-g1400
Post by: My427stang on November 19, 2023, 08:34:17 AM
I believe there are two Offy options, one for sideways, one for setback/forward.  Could you have bought the wrong ones?
Post by: Nightmist66 on November 19, 2023, 11:40:31 AM
If you wanted to switch throttle bodies, these will fit the tunnel wedge easily. I understand if you want the 4150 look, though. Just throwing it out there.
(https://i.postimg.cc/Cx1wxXhZ/output-image1700411113551.jpg) (https://postimages.org/)
(https://i.postimg.cc/7ZWwG9hK/output-image1700411496630.jpg) (https://postimages.org/)
Post by: pbf777 on November 20, 2023, 12:36:55 PM
     I believe the Offenhauser #5880 provides the pair of spacers which offset each carburetor 1/2"; whereas the #5832 provides the pair of spacers intended to rotate the carburetors 90 degrees.  Unfortunately, the later is intended to be mounted to manifolds which present the 5-5/8" x 4-1/4" bolt Carter AFB & Quadrajet pattern, adapting the 5-5/8" x 5-1/4" Holley pattern for the carburetor mounting.   ;)
     Hence, why one may find that the best way is to do a little custom welding & machine work to present that which is needed.   :)
     Oh,............I don't know what size of a welder you may have acquired but when welding aluminum, figure you'll need twice the amps as that of steel, and I would guess that for this job anything less than say 200amp. capacity just isn't going to be enough for a good result.   :-\
     Scott.
Post by: 62_BattleBird on January 08, 2024, 11:26:52 PM
[/quote]
[/quote]
Excellent, will do. Thanks for the advice!
Post by: 62_BattleBird on January 08, 2024, 11:36:25 PM
I thought about doing this and may still go that route. I'm currently working on shaping what I need out of plates of 3/4in aluminum, so we'll see what happens. Thanks for the advice.
Post by: 62_BattleBird on January 08, 2024, 11:38:23 PM
Very cool. What are these?
Post by: 62_BattleBird on January 08, 2024, 11:44:50 PM
     Scott.
Thanks for the info Scott; that is indded the route I'm going to attempt. Thanks also for your insight on the aluminum welding; luckily I managed to get ahold of a 200amp welder so I should be good to go there.
Post by: GerryP on January 09, 2024, 08:10:45 AM
If it were me, I'd find someone who can do 3D printing.
