FE Power Forums => FE Technical Forum => Topic started by: Dubs1 on April 29, 2023, 09:22:38 PM
Title: FE/EDELBROCK WATER PUMP ISSUE
Post by: Dubs1 on April 29, 2023, 09:22:38 PM
Does anyone  have  a brand name  or  make  of a radiator  hose to fit the 2 1/4  outlet  for the Edelbrock FE water pump.  I have checked with local  auto part stores and  they dont have any hose in stock that size.
Pls advise
Larry   in Denver
Title: Re: FE/EDELBROCK WATER PUMP ISSUE
Post by: fryedaddy on April 29, 2023, 10:40:45 PM
i lubed and stretched a 2 inch over mine
Post by: Tunnelwedge on April 30, 2023, 05:42:18 AM
Which car?
https://www.macsautoparts.com/radiator-hose-set-with-script-390-and-428-cobra-jet-v8-90-18514-1.html
Post by: fairlaniac on April 30, 2023, 07:07:38 AM
Pls advise
Larry   in Denver
In my '66 Fairlane with Edelbrock pump, I used a 1964 Thunderbird lower hose. I go it from one of the online Ford parts vendors. Lower Hose: C4SZ-8286-A the Motorcraft equivalent is KM-128. Modification:  3/4" trimmed off rad. side. I understand that was a one year only hose and this hose replaced it C4AZ-8260-D. The -D crosses to a KM-310 Motorcraft but I do not know if that will work for you or not as I've never had one.
Post by: Dubs1 on April 30, 2023, 03:49:49 PM
Pls forget my last question fellows,  Being an old fart  and  near cited   I am only blind  in one eye  I just cant see outa the other,  the Edelbrock outlet is in fact  OD  two inches.
Post by: fairlaniac on April 30, 2023, 04:11:41 PM
Here is the lower hose I use.
http://www.fairlanet.com/images/C4SZ-8286-A.jpg (http://www.fairlanet.com/images/C4SZ-8286-A.jpg)
Post by: Dubs1 on May 03, 2023, 09:03:37 PM
Thank you fellas  !!!
