		FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: blykins on March 28, 2023, 08:38:06 AM
				Still catching up....
 Performance Summary:
 Cubic Inches:    429           Dyno brand: Stuska
 Power Adder:   N/A            Where dynoed:  Dale Meers Racing Engines
 Peak Horsepower:  471 @ 5600
 Peak Torque: 485
 Horsepower and Torque Curves:
 Engine Specifications:
 Block brand, material, finished bore size, other notes:  Robert Pond Motorsports, cast iron, 4.250"
 Crankshaft brand, cast or forged, stroke, journal size:  Factory Ford 390
 Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat 6.490"
 Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec forged, flat top
 Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Federal Mogul
 Piston rings brand, size, other notes:  Total Seal 1.5/1.5/3mm
 Oil Pump, pickup, and drive:  M57HV, Canton front sump pickup
 Oil pan, windage tray, oil filter adapter:  Canton front sump
 Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller, 233/243 @ .050"
 Lifters brand, type:  Morel
 Timing chain and timing cover:  Cloyes billet timing set, factory timing cover
 Cylinder heads brand, material, port and chamber information:  Factory C5AE-F, non-ported
 Cylinder head flow in cfm at inches of lift (28" H2O pressure drop):
 Intake               Exhaust
 .100               .100
 .200               .200
 .300               .300
 .400               .400
 .500               .500
 .600               .600
 .700               .700
 .800               .800
 Flow bench used, location:
 Intake valve brand, head size, stem size:  SI stainless, 11/32", 2.190"
 Exhaust valve brand, head size, stem size:  SI stainless, 11/32", 1.750"
 Valve springs brand, part number, specs:  PAC dual springs
 Retainers and locks brand, part number, specs:
 Rocker arm brand, type (adjustable or non-adj), material, ratio:  Lykins Motorsports, roller tip non-adjustable
 Rocker shafts and stands, brand, material:  POP HD
 Pushrods brand, type, length:  Custom Trend
 Valve covers, brand, type:  Cobra Lemans
 Distributor brand, advance curve information:  Factory FE with steel gear & Pertronix
 Harmonic balancer brand:  Powerbond
 Water pump brand, type (mechanical or electric):  Factory cast iron replacement
 Intake manifold brand, material, porting information:  Ford Sidewinder
 Carburetor(s) brand, type:  Holley 800
 Exhaust manifolds or headers brand, type: Dyno headers
 (https://live.staticflickr.com/65535/52385218866_fdf385e852_z.jpg)
				Nice Brent looks great and probably sounds better. Curious how the pond block was as far as the machining, was everything smooth going.
 I much prefer the Pond blocks.
