		FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: blykins on March 28, 2023, 07:56:19 AM
				Built this one a couple of years ago, never did put it up here.  Nice to see the old flat tappers making some horsepower.
 Performance Summary:
 Cubic Inches:   465            Dyno brand:  Stuska
 Power Adder:   N/A            Where dynoed:  Dale Meers Racing Engines
 Peak Horsepower:  676 @ 7200
 Peak Torque:  595
 Horsepower and Torque Curves:
 Engine Specifications:
 Block brand, material, finished bore size, other notes:  BBM cast iron, 4.310" bore
 Crankshaft brand, cast or forged, stroke, journal size:  RPM, 3.980", 2.200"
 Connecting Rods brand, material, center to center distance, end sizes, bolts:  Molnar 6.800"
 Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Racetec forged, 12.5:1
 Main Bearings, Rod Bearings, Cam Bearings brand and size:
 Piston rings brand, size, other notes:  1.5/1.5/3mm
 Oil Pump, pickup, and drive:  M57HV, Milodon pickup
 Oil pan, windage tray, oil filter adapter:  Milodon, no tray
 Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"): Custom Lykins Motorsports solid flat tappet, nitrided
 Lifters brand, type:  Trend tool steel
 Timing chain and timing cover:  Ford Racing timing set, factory timing cover
 Cylinder heads brand, material, port and chamber information:  Out of the box Trick Flow
 Intake valve brand, head size, stem size:  2.190", 11/32"
 Exhaust valve brand, head size, stem size:  1.625", 11/32"
 Valve springs brand, part number, specs:  Manley Nextek
 Retainers and locks brand, part number, specs:  Manley titanium
 Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D street, 1.76
 Rocker shafts and stands, brand, material:
 Pushrods brand, type, length:  Custom Trend
 Valve covers, brand, type:  FE Power
 Distributor brand, advance curve information:  MSD
 Harmonic balancer brand:  Powerbond
 Water pump brand, type (mechanical or electric):  CVR electric, FE Power water pump adapters
 Intake manifold brand, material, porting information:  BBM Tunnel Wedge
 Carburetor(s) brand, type:  Quick Fuel 750 x 2
 Exhaust manifolds or headers brand, type:  Dyno headers
 (https://live.staticflickr.com/7809/40271907003_a06178c20d_z.jpg)
				I don’t know it just seems to me that 452-465 ci alway makes good power. Whether it’s a good stroke to bore or what but it just to have good results.
 Yep, it seems that way to me too.  My Tunnel Ports do really well with that bore/stroke combination.  In the SBF world, it's a 427-434 that makes a ton of power for what it is.
