FE Power Forums => FE Technical Forum => Topic started by: fryedaddy on August 12, 2022, 03:45:32 PM
Title: still no fuel
Post by: fryedaddy on August 12, 2022, 03:45:32 PM
i recently bought my papaws old truck back-73 f250,360 2bbl, 4 speed.i cleaned the gas tank,new sending unit,new fuel pump,kit in carb and a new clear fuel filter.heres the problem,everything seems to be working,filter filled with fuel,plenty of pressure,BUT,if you fill the carb bowl with fuel and a little down the carb  it runs for about a minute and dies like its out of fuel?
Title: Re: still no fuel
Post by: 390owner on August 12, 2022, 03:54:18 PM
Is fuel getting in carb sounds like stopped up where the line goes to carb or float stuck closed
Post by: RustyCrankshaft on August 12, 2022, 04:25:35 PM
Does it have dual tanks? in 73 the dual tanks were manually switched by a valve on the floor and the dash switch was only for the gauge. I've found a lot of times guys had the valve on the wrong tank and didn't realize it. I may have done that once.......
Post by: fryedaddy on August 12, 2022, 04:43:55 PM
single tank,i took it off and cleaned it.fuel filter is 1 foot from carb and its full of fuel
Post by: 1964Fastback on August 12, 2022, 04:52:56 PM
I would fill up the carb bowl and then disconnect the fuel line and put it into a coffee can or jar or something and start it up and see how much gas flows.  Obviously be careful.  Make sure what you are using can't fall over, only run for a few seconds, etc.  If gas flows into the jar okay, you know it's something with the carb, like the float or needle.
Pat
Post by: fryedaddy on August 12, 2022, 05:07:38 PM
the filter fills instantly when you crank it.it has plenty of pressure because gas was squirting everywhere till i tightened  the clamps
Post by: fryedaddy on August 12, 2022, 06:35:39 PM
got it, the screw in filter that screws into the front of the 2bbl carb was plugged.i had blew through it when i rebuilt the carb and it seemed ok  fires right up and runs good now.THANKS
Post by: fryedaddy on August 13, 2022, 10:22:51 AM
this old 360 is one of the fastest starting FEs i've had.i had a cougar with a 289 that was a fast starter.i used to bet 20 dollars to some of the gm guys that my car would start quicker than theres would.i never lost.i also have a 87 2.9 ranger that starts fast in any weather
Post by: galaxiex on August 13, 2022, 02:48:13 PM
I've had old Fords that would start in what seemed like 1/4 revolution of the crankshaft!
You just barely touched the key to the "start" position and it was running.
Post by: machoneman on August 13, 2022, 05:28:09 PM
Yep! Once warmed up or hot, one touch would start the engine.
Post by: 390owner on August 13, 2022, 06:28:03 PM
Just as I thought Glad you got it going
Post by: Falcon67 on August 15, 2022, 09:43:54 AM
The Falcon back when it was pretty much original with the 289 and 3 speed.  I'd tune it once in a while, set the points, clean and adjust the 4100.  Touch the key, maybe once turn and it'd light right off.
