FE Power Forums => FE Technical Forum => Topic started by: BigBlueIron on May 18, 2022, 01:30:23 PM
Using a set of lightly used L-2291 pistons on a new build. (cleaning out under the bench) Figured I would get some new pin locks and unfortunately it appears the original LR-N540098 locks are no longer available nor can i find old stock. Anyone have a recommendation on what I can use in place of?
Some of my true arcs
Speed Pro 390 cast .. never installed
1.101 -- 1.105
Forged 390 piston.. installed, not run
1.080
.052
Factory 360 used
1.066 -- 1.075
.050 -- .051
391 FT.. used
1.075 -- 1.082
.052 -- .053
McMaster-Carr
https://www.mcmaster.com/retaining-rings/internal-retaining-rings-6/
O.D. Thick
1 1/16" 1.13" 0.056" 1.18" 0.05" Rockwell C40 7,560 Magnetic ASME B18.27.1 25 99142A470 7.10
Ricky.
