		FE Power Forums => FE Technical Forum => FE Engine Dyno Results => Topic started by: frnkeore on April 03, 2022, 05:20:36 PM
				I went to the Portland Swap Meet, Fri & Sat. While there I stumbled on to this Algon FI so, I thought I'd capture some pictures of some FE history.
The thing that stood out, was the FI pump. I don't remember seeing one, or one like it. There was a thread on the 332/428 forum last month, regarding Algon FI but, those manifolds have runners that come off parallel to the ports, rather than vertical, like this one. It also, looks like the angled manifold, may have had two different size throttle bore sizes. Maybe two sizes on the vertical stack, too? Anyone else have pictures of Algon FI systems?
This one is still homeless so, if anyone has more questions, you can call the number in the picture. As I remember it has LR ports.
EDIT:
Jay, I put this in the wrong section, could you move it to "FE Tech Forum?
