FE Power Forums => FE Technical Forum => Topic started by: 1967 XR7 GT on February 07, 2022, 06:30:12 PM
Title: Heating Issues With Half Filled Blocks ?
Post by: 1967 XR7 GT on February 07, 2022, 06:30:12 PM
Half filled with hard rock, on the street, over heating Issues?
Title: Re: Heating Issues With Half Filled Blocks ?
Post by: blykins on February 07, 2022, 06:54:26 PM
You may see increased oil temperatures.  I generally advise customers to run an oil cooler.
Post by: Posi67 on February 07, 2022, 08:39:55 PM
You might even see lower coolant temps but the oil will certainly get hotter. What Brent said about an Oil Cooler and even an oil temp gauge would be wise.
Post by: Falcon67 on February 08, 2022, 10:05:19 AM
Echo - haven't personally done it but the typical word and consensus from those that are running same is cooling system - no problem if it was up to snuff in the first place, add an oil cooler.
Post by: shady on February 08, 2022, 05:06:22 PM
What kind of cooler are you guys using? Big, little, simple or fan cooled?
