FE Power Forums => FE Technical Forum => Topic started by: 1968galaxie on January 16, 2022, 11:39:56 AM
For solid lifter or hydraulic roller FE engines.
I see that many lifters are dual use - BBF and FE or sometimes SBF and FE.
However the FE push rod lifter side is 3/8" ball.
Does one require FE push rods with the 5/16" ball end to use these lifters?
Yes, But They Are Available From The Well Known Suppliers. I Had The Same Situation On My 428/Solid roller Cam With Morel Pressure Oiled Lifters And Harlan Sharp Rockers.
