FE Power Forums => Non-FE Discussion Forum => Topic started by: gregaba on September 12, 2021, 12:09:37 PM
About 15 years ago I sold my 56 Mercury to my friends father. I didn't want to sell the car because it ran perfect and everything worked on the car. It only had 37,000 milrs on it when I sold it.
My friends father passed away last year and he wanted to install an FE in it so he bought a 78 Ford pick up with a good enginr [360] in it and pulled the 312.
It still ran perfect and had only added about 4,000 miles on it since he got it from me.
Well my friend went ahead and sold it back to me.
Now all I have to do is find a car for it.
Greg
I ran a '54 Customline, with a 312 I put in it, for several years. When I switched to a 'C' cam, the engine was already in the car. I 'invented' a tool to replace the nailhead lifters while laying on my back and weaseling them past the crank. Had my brother clip clothes-pins on, up in the valley, to hold the lifters in place until they were all in and I could put the cam in. Had to remove the grill and radiator to get a long-enough shot. We were working in the back yard with a flashlight to see with. Ultimately had the factory 'race' dual quads and a Paxton blower. It, too, was designed as a race unit and the part of the front of the casting intended to house the boost-limiter was simply left unmachined. The impeller was also significantly different.
The fuel pump had to be boost-registered, requiring modifications that sent blower pressure from one of the carb hats to the back side of the pump diaphragm. Thus, as the pressure went up, the fuel pressure went up as well. At idle, fuel pressure was at about six pounds, but when I had my foot in it, the pressure gauge was pegged at 15 pounds. Great fun on Telegraph Road with the 421 Pontiacs and 409 Chibrolays. ;)
Sounds like a nice 54.
My 55 custom was a great car and I wish I had keep it.
I just loved the 312 engine because in the early 60's it was still a good choice for racing and would hold it's own with the Pontiacs and chevy's at the time.
I remember those boost pumps and wonder if you can still get a rebuild kit for one or if you would have to make your own diapharms for it.
Greg
I used the stock diaphragm. One modified the pump by drilling and tapping the housing to fit a hose nipple. The hose went from the carb hat to the pump. I used two-part epoxy as added insurance since the wall of the pump by the diaphragm wasn't any too thick.
