FE Power Forums => Vendor Classifieds => Topic started by: Ford428CJ on April 17, 2013, 10:44:54 PM
Title: Carb Rebuilds~
Post by: Ford428CJ on April 17, 2013, 10:44:54 PM
Hey guys. Here soon, I'll be doing another run of carbs for people. I'm trying to get caught up with the ones I'm doing now. So, I'll be offering forum members a Deal $60 for a 4bbl. $35 for a 2bbl + Parts.  I will post when this deal will happen. So if you are looking for someone... Look no further. I have done quite a few for the others off Ford FE site. I want to do the same here.
What we do for you!
1) Set everything back to book spec (Floats levels, Idle mixtures, primary/ secondary throttle settings)
2) Go through all passage ways. I have the special carb tool kit.
3) Clean all parts with a Chem dip and tumbler.
4) Check all Floats for leaks. If Brass, repair as needed.
5) Polish Brass floats (unless if they are plastic).
6) Check all parts for loose, missing hardware and cracks.
7) Check to make sure all surfaces are flat. If not , true up as needed.
8) Re-blue the shafts and butterflies if needed.
9) Final assembly, check all new gaskets and make sure there are no obstructions and Torqued to book spec. I coat all the gaskets. If you decide to do a jet change, the gaskets wont stick but they will seal with no leaks.
Thanks for your time and Thanks Jay for letting me post!
http://www.hillsideauto.org/4bbl-carbs.html
Title: Re: Carb Rebuilds~
Post by: Ford428CJ on April 17, 2013, 10:50:44 PM
(http://i47.photobucket.com/albums/f193/ford428cj/Larry%204100/IMAG0191.jpg) (http://s47.photobucket.com/user/ford428cj/media/Larry%204100/IMAG0191.jpg.html)
(http://i47.photobucket.com/albums/f193/ford428cj/Larry%204100/IMAG0188.jpg) (http://s47.photobucket.com/user/ford428cj/media/Larry%204100/IMAG0188.jpg.html)
(http://i47.photobucket.com/albums/f193/ford428cj/Larry%204100/IMAG0185.jpg) (http://s47.photobucket.com/user/ford428cj/media/Larry%204100/IMAG0185.jpg.html)
