FE Power Forums => FE Technical Forum => Topic started by: Saltshaker on July 21, 2021, 06:39:37 PM
Engine ran flawlessly in my old car but I needed to remove the 1” open spacer from the rpm intake and it now hesitates off the line. Would removing the spacer cause this and any suggestions for a cure?
Jon
Did you touch anything else at all? I'd start simple with something I see all the time, is the accel pump arm(s) adjusted correctly?
You said "in my old car"
Is it installed in a different vehicle now, if so, how much different is the weight and drive train?
same wt, but this car has a automatic with a 1800-2200 converter
Jon
