FE Power Forums => FE Technical Forum => Topic started by: CV355 on July 17, 2021, 04:59:15 PM
Edit - This wound up being a non-issue...
I have had it happen to me a couple of times.
First time I droped the pan and didn't find anything wrong so I just used a 1 ft. pipe over the lever and it went in with quite a bit of pressure.
I am not a tranny expert so you might want to call your shop and ask them.
Greg
Greg
I was tempted to do that. What could it damage?
It sounds like the shift arm is not properly engaged with the spool valve on the valve body. I'd check with Mr Broader before I did anything drastic.
I'm getting in touch with Broader today. Thanks!
This wound up being a non-issue. There was nothing wrong with the transmission at all. I did something mildly stupid but at least had enough common sense to ask about it before doing something *really* stupid. Here's a free laugh at my sleep-deprived expense:
Broader did a fantastic job, but I mixed up linkages. The ISS were different between my old C6 and new C6, new one wouldn't accept an external NSS. So, I looked for alternatives and opted for a B&M shifter where the NSS and RLS are in the shifter and not on the transmission. I blame it on lack of sleep, but when I was setting the push/pull cable length, I said "Hey, I should make sure the shifter position matches the transmission position first before connecting anything and adjusting travel." Shifter was in neutral. Stupid me, I picked up the (new) kickdown arm and slapped it on to "make sure the transmission was in neutral." There was never an actual gear selector arm installed on the shaft, and I had a bag of about 10 different arms on the workbench...
Mr Broader sparked my memory when he asked which shaft was stuck. In a moment of clarity and embarrassment, I went back to the garage, pulled out the new gear selector arm, put it on, click click click just fine.
I removed the original post because I don't want anyone to think there was a problem with Broader Performance, they've been excellent.
Glad you got it figured out. Broader Performance has always been too notch for me ;D
Good all is well
I have had a few moments as such :)
Ricky.
