FE Power Forums => FE Technical Forum => Topic started by: 390rpm on June 18, 2021, 06:37:16 PM
Title: Roller Rocker Body Valve Spring Clearance
Post by: 390rpm on June 18, 2021, 06:37:16 PM
I'm going over my rocker arm alignment and noticed that a couple of the rockers are touching the valve spring. I'll try to get a picture. It looks like it's touching on the sides where the top wire of the spring is clocked facing the rocker arm body.
Title: Re: Roller Rocker Body Valve Spring Clearance
Post by: 390rpm on June 19, 2021, 01:02:06 AM
Scratch that. I was wrong. They only touch when rocked back more than it ever will while running.
