FE Power Forums => FE Technical Forum => Topic started by: chris401 on April 03, 2013, 11:17:43 PM
Good evening. Drifter from fordfe here with an intake question for my 65 F250 4spd, 4.10s. Future build: stock C0AE flat tops, C7AE-A heads (rebuilt), 252H and C2 Shortys. Looking at Jays test data it looks like the Edelbrock SP2P would be a better choice over the Offy Dual Port due to port hieght for secondaries . Any sugestions this side of a 300 six?
Thanks, Chris
Can you give more details about what you are trying to accomplish? Are you looking at those two intakes because mileage is your chief interest? If so, I'd go with the SP2P. But if you are concerned about maximizing low end torque, I think I'd be looking at an Edelbrock Performer (not a Performer RPM).
I'm looking for mileage. 3,000 rpms @ 70 mph. I may be driving annual mileage from 11 to 33k. Its suited up for most trailers now but towing isn't my concern at this time. I also have a 390 Holley. Would this be a good complement to the SP2P?
Thanks,
Chris
The SP2P is your best bet if mileage is the major concern, and I think the 390 Holley would work fine with it.
Appreciate the info. All I'm missing is the cam and intake. I have a couple of factory cams that will hopefully grind to the 252h cam specks.
Thanks again
I'll get flack for even suggesting this, but I'd be looking at using a 750 quadrajet on such a build. Tiny primaries and adjustable APT setting would make it a super gas sipper on the highway and have some roar with the bigger secondaries. Food for thought, just dont throw the food at me. ;)
What? A Quadrajunk! Heresy, I say! Draw and quarter him!
Actually, that is great advice and a well set up Q-Jet would be the best ticket for mileage. The only issue is few these days know how to set the jetting and other parameters unique to this style of carb (at least compared to a wider knowledge base among Holley fans). If you have access to a Q-Jet guru or a known supplier of well rebuilt units I'd go for it.
Good suggestion. The Rodchester design has crossed my mind.
Chris,
If towing is not a big concern and you're looking for mileage how bout a taller gear? If you're running 4.10s you've got an opportunity there, say even going down to 3.50 or 3.25. My Galaxie came stock with a 3.00, and the Fairlane with a 2.70!
Bruce
An over drive trans would be high on my list as well.
Pitchforks, Aye! Get the torches! ;D
For such a mild engine as this 352 is looking to be given the specs above, I'd say an OEM 750 (smaller of the two q-jets) rebuild from a good core would be my route. Jetting changes are pretty simple once you've done them a few times. If he's not comfortable with doing the rebuild, I'd highly suggest some of the performance carb guys out there like Dean Oliver or Sean Murphy. Sean did my original 750 on my stock-ish 390 and it ran perfect and I saw 20mpg on the highway with 3.00 gears. Dean built the 800 I'm running on my new 428 that is pretty warmed over and makes lame vacuum at idle with the big roller cam. It runs perfect and I've seen very good mileage with it as well. Regardless, the small primary bores, particularly on the 750cfm carbs make them very attractive for something mileage oriented. The APT setting also makes the primary rod depth infinitely adjustable when you're humming down the highway, so you can get every last mpg possible very easily provided the secondaries are shut at highway speed.
The axel is a Dana 60. 3.73 and a GV may be in the future.
Parts I'm coming across have dictated my direction. For now the short stroke will be in place and the original 352 be set aside for future build. I have located a Doug-Nash under drive box which will complement a NV4500 with 3.54 in the rear. Employing the under drive gives me a 4.24:1 axel ratio for towing. 3.54 OD will put me about 1890 rpm @ 70mph. But for now the 4 speed, 4.10's, short stroke and SP2P will be the motivation.
I also picked up a reman Q-Jet from a 350
They're long out of print but you might try to find a Holley 6708. It's a special-purpose 650 DP that has big-'n'-little butterflies. I used one on a tinkered-with 302 in a '72 E-150 and it did excellently on the h'-way. You can modulate with your foot and stay out of the secondaries, but have a little extra when you need it. And I agree with Jay regarding the regular instead of RPM manifold. And there's too much of the band-aid to the odd-ball designs.
Ill look into that carb. DP be a little much for my 359 in a 3/4 ton.
I have a 78 F-150 with a 460 C-6 and a 2.75 gearset. Back when it had a good engine in it, .040 over, zero decked, Reed 252/260 advertised with a 112 lobe sep, roller rockers, stock intake, an Edelbrock 750 leaned out on the cruise mode to just before it was surging. Had stock exhaust manifolds and dual 2 1/4 with flowmasters. The best mileage I got with the truck was 16.4 mpg's on flat highway at 60 mph towing an empty open car trailer. This mileage was not computed from my odometer. I topped off to the top of the filler neck, drove 100 miles going by mile markers and topped off again to the top of the filler neck. I was surprised at the mileage. I did the mile marker/top-off test several more times and came up with similar results.
Unfortunately later on the engine was severely overheated which started the downward spiral and one day I heard a noise which lasted for about 2 seconds and the end result is the #8 piston ended up everywhere else in the engine. I put in a stock 460 from a 78 Lincoln. With the same carb, intake and ignition settings the best I can get out of this engine is about 13. My feeling is the compression and .040 quench was a big factor in acheiving better mileage.
I have been really happy with the Edelbrock carbs. I've been running the same 750 on my F-150 for 9 years. I haven't touched it after the tuning was done----about 8 years ago. They are pretty much set-it and forget it.
That's good mileage for a 460 in a truck. The current build is a .040 over 64 352 and C7 heads. Plans are to save the complete original 352 for a future upgrade. Probably one of the scat cranks with wide rod journals. Through a 3.54 and NV4500 I will have a over drive of 2.76, in this case about 1890rpm @ 70mph. I would like to modify the original carb and intake to match the build but that's way down the road.
I've thought about making one of my trucks a manual trans. An NV4500 has never crossed my mind. I guess because a ZF5S42 will bolt right to the 460. I do like the idea of an NV4500. It's a good trans. I think I've rebuilt two of them in the past 7 years----I own a tramsission shop. Does the NV4500 bolt to the FE behousing?
The overdrive ratio in the NV4500 is .73:1. If your rear gear is a 3.54 the operating ratio in OD will be 2.58:1.
With your current ratio of 3.73 would make the OD operating ratio a 2.72. Honestly, I would leave the 3.73 in place and save the money. You probably wouldn't get any measureable gas mileage gains going from 3.73 to 3.54. Infact, you might find that with carrying a load the mileage gets worse as the engine is below peak torque and lugging. Then you're back to driving in 4th gear. No performance gains and an empty wallet doesn't increase gas mileage very much.
Mark
Your right, I didn't remember correctly. The RPM figures are actually 1887 at 70mph. What I have in mind (future build) is to set up a Doug Nash Under Drive case behind the NV. It will give me a 4.24:1 ratio for towing and a 3.54:1 when running empty. Until then it will remain stock 4spd/4.10. Personal email sent.
Thanks I've thought about making one of my trucks a manual trans. An NV4500 has never crossed my mind. I guess because a ZF5S42 will bolt right to the 460. I do like the idea of an NV4500. It's a good trans. I think I've rebuilt two of them in the past 7 years----I own a tramsission shop. Does the NV4500 bolt to the FE behousing?
Mark
An nv4500 will bolt up to an fe with an adapter plate. Advance adapters makes an adapter plate to mount a dodge pattern nv4500. I'm gonna use a late model Chevy 4500 because I wanted the fixed rear output. I have to change over to dodge input and non hydraulic throw out . A dodge is pretty much a bolt in with the adapter.
Hope this helps.
Will
I have paused the budget build for now. After 21 years of shelf life the .040 352 pistons turned out to be worn too much. The budget build was pushed over the limit at this time. I'm refreshing a 68 2v 390 to power my daily driver while the 401 gets inspected and detuned. After the 401 is back in Ill sell the 390 and resume the 352 build.
