FE Power Forums => Private Classifieds => Topic started by: BigBlueIron on April 27, 2021, 11:42:03 AM
Has anyone picked up a Trick flow that they no longer need and are willing to shake it loose. New is few months out from talking with Trickflow.
I have a real clean Dove, I hadn't thought about selling it as it is all set up with 660s, linkage etc
Well that might work but I'm not in need of carbs.
Search/look for Carl’s ford parts in Ohio. He may have a trick flow.
PM sent
Trick flow is coming out with a tunnel wedge??
I have anew BBM
A few years ago Trick Flow started showing around a prototype Tunnel Wedge intake, with the description that it was coming soon. But they kept pushing back when it was going to be available, and that went on for a couple years or more. Finally at one point the Trick Flow Tunnel Wedge intakes suddenly became available, and quite a few people jumped on them...then they were out of stock again, with no word on when they would be available again.
By all reports I saw it seemed to be a quality part, and a few people showed their builds with them, but I don’t think I ever saw anyone do a side by side comparison with the Trick Flow to an original, or a Trick Flow to a BBM version. Hopefully they will be back.
If you do a search on here you should find some info.
http://fepower.net/simplemachinesforum/index.php?PHPSESSID=jf1tdedfpeg5mu8gvika9idmb7&topic=9343.0;all
BBM don't have any instock? I used a BBM one on my build
BBM's are available.
This is a small cube (364") build. A tunnel wedge of any brand is probably a poor choice for a 352. I feel the Trick Flow version maybe better suited with its slighter smaller plenum and runner size.
Thanks for the reference! Great post <> didn't know.
Have you found/bought a TW yet? Joe-JDC
