FE Power Forums => FE Technical Forum => Topic started by: centredautomag on January 15, 2019, 09:40:55 AM
I need to shim my rocker stand .240 is there some shim kit avaliable
Thanks Marc.
I made my own. I got some 1/4" steel flat stock and used a drill press, a die grinder, and a large stone to make sure it was flat and even. After I trued it, it came out to about .240", which is what I needed to shim my Harland Sharps with POP shafts, stands, spacers. If you are planning on running studs, I bought some custom length ARP's from one of the vendors on here. I had to neck down the oiling one, as it was a straight 3/8" stud. Here's my homemade junk:
(https://i.postimg.cc/FH7M8WRC/20180902-165845.jpg) (https://postimg.cc/G4ngsjvv)
(https://i.postimg.cc/25WP81n4/20180902-165933.jpg) (https://postimg.cc/KKZ90vqz)
(https://i.postimg.cc/JnWSyRQS/20180903-144227.jpg) (https://postimg.cc/TyCtFMFc)
Very nice job. Time to get the tools out and play. thanks Marc
I know this is a dumb question, but how do you know when you need to shim your rocker stands ?
Thanks Clint
Thanks Clint
When the rocker arm pattern on the valve stem isn't where you want it to be.
Hey Nightmist 66 just noticing the single spring. Is the conical spring stronger than a regular spring or is the cam very mild seat pressure wise.
The springs are/were a beehive. Very similar to the conicals. They were 155/377open for a custom solid flat tappet that just bit the dust a short time ago. They were set up with different shims/locks for break-in. Had the lightweight shell lifters in it and custom .115" wall 5/16" chromemoly pushrods. Now moving on to a slightly larger solid roller and dual spring setup...
Ok thanks, so did the cam go on breakin or just over time.
Happened during break-in. Brand new scratch build. 50 mins. run time. :(
If those were the valve springs that you used for break-in, that's why it wiped....
So, have you had experience with these springs and flat tappets for break-in? They were set up with less shim and +.050" locks to keep the pressure down. Is it due to rate on these springs?
Yes, I use them quite a bit, but I always put a single spring or low pressure dual spring on during breakin. I aim for spring pressures at around 90-100 seat and under 300 open. You were likely still pretty high on pressure.
A .050” valve lock change will only change the spring pressures by 15-18 lbs or so.
Seat pressure was around 100psi and I can't remember what the open was.....
You can multiply your cam lift times the spring rate and add it to the seat pressure to find out.
It would take a lot of change to drop 55 lbs off the seat though.
