FE Power Forums => FE Technical Forum => Topic started by: daryl w66 on December 12, 2020, 10:22:03 PM
Hello. I'm looking to buy a new fuel log for my 2 quick fuel 600 vac sec. I want to put a return line system in my 66 fairlane. Don't need any leaks. I'm hoping for some help here. I don't know what to look for and which is a good brand name that will work with no problems and where to buy the right one. Thanks!
http://www.cobranda.com/bigbl2x4fulo.html
Here is the set up i will be using Regulator is Aeromotive A1000 Return style https://aeromotiveinc.com/product/a1000-carbureted-bypass-regulator/
I just made a custom mounting bracket and my lines will come in from the back of the engine line in from pump is on the side and the return is the one at the bottom of the regulator.
