Author Topic: Fe Engine  (Read 3102 times)
stubbie
Fe Engine
« on: May 07, 2021, 10:41:28 PM »
long time observer on the forum but don't usually post. Fe engines are pretty scarce here on the island but last year I managed to find a block and the guy had another complete engine sitting in his shed so I grabbed that one as well. Anyway I just got to tearing it down. Don't know a lot about these engines so not sure what I have. It looks like it might have been a truck engine as it has an oil filter that sits horizontal. The block is a C7MEA, so a 67, possible 428 block? A 13/64 drill bit fits between the cylinders but not a 15/64. It's a 4.050 bore, 6.49 stroke so 390. Rods are C7AE-B 427/428, 2U crank, heads are C2SE 6090B possible 62-63 406CID? My measuring stick is broken but the valves appear to be around 2.03 intake and 1.60 exhaust. If I wanted to use this in a car would the crank snout be different? Thanks for any advice
Re: Fe Engine
« Reply #1 on: May 08, 2021, 12:47:52 AM »
See if this link below will work for you, it was put together by one of our members and tells how to identify a real 428 block, or one of the occasional 361/391 FT blocks that were cast with 428 cylinder cores. First step is to look on the side of your block to see where it was cast, C7ME-A blocks were cast at both the Dearborn Iron Foundry (DIF) and the Cleveland Foundry (CF). The foundry logo will be on the side. If it is a Dearborn Iron Foundry (DIF) block you can tell by the shape of the deck coolant passages if it is a true 428 or FT with 428 cylinder cores. The diagram of the shapes is in the document I linked, but if you can’t get that to work I can post pictures here. If your block is a FE from a passenger car or pickup truck then it can’t be a 428 with 4.05” bores. Your block would have to be a FT block, from a medium or heavy duty truck, with the bigger FT distributor pilot hole, for it to possibly have the 428 cylinder cores with the 4.05” bore. C7ME-A blocks were used in both the ‘67 & ‘68 model years, you will have to look at the actual casting date code under the oil filter adapter pad to see when it was cast. For that era FE there may also be an engine assembly date stamped on one of the “ears” on the corner of the block, usually the drivers side front. Those will help identify the actual model year. If the C7ME-A block is from a ‘68 passenger car it might also have a partial VIN stamped on the back. I know it appears to be from a pickup truck going by the oil filter adapter, but always good to check, after 50 years lots of engines were swapped. A C7ME-A block can be any FE/FT engine Ford was assembling in the ‘67 & ‘68 model years, except a 427. A 428 is one possibility, but not the only possibility. The block casting numbers used after the ‘64 model year are basically meaningless on most FE’s for identifying the original size of the engine assembly, Ford just wasn’t using that casting number for that purpose. The crank snout on light duty (F100-F350) pickup FE’s are the same size as the passenger car FE’s, it’s only the FT cranks that can have the larger crank snouts.
Link to 428 block identification document:
https://www.dropbox.com/s/jqrf7hv2ekxvcbk/428%20Block%20ID.docx?dl=0&fbclid=IwAR2DQdr6xbyOoylZGrvnzzmH0_8DTIvuZM7l4N7z1hEwQdo1_qPHx4M9HN4
« Last Edit: May 08, 2021, 01:00:11 AM by thatdarncat »
stubbie
Re: Fe Engine
« Reply #2 on: May 08, 2021, 07:15:24 PM »
Thanks I'll check it out. What about heads anything special?
427John
Re: Fe Engine
« Reply #3 on: May 08, 2021, 07:28:55 PM »
The C2SE-B heads are indeed the 406 heads,they may have also been used on late 390HP's.
FE4SPDMustang
Re: Fe Engine
« Reply #4 on: May 08, 2021, 10:26:25 PM »
C2SE-Bs are not 406 heads. C2SE-C are. They're a nice head if you aren't running them in a tower car.
427John
Re: Fe Engine
« Reply #5 on: May 09, 2021, 03:18:43 PM »
I've got both C2SE-B's and C2SE-C's,they look almost identical and I was under the impression the B's were used on very early 406's as well as late 390HP's,regardless they are both good heads and will make more compression than the standard heads.The C3AE-C heads were used on late 406's and introduced the larger exhaust valve along with the spring seat cups.
« Last Edit: May 09, 2021, 03:21:58 PM by 427John »
Re: Fe Engine
« Reply #6 on: May 09, 2021, 05:46:01 PM »
Off of Mustang Tek
stubbie
Re: Fe Engine
« Reply #7 on: May 09, 2021, 06:35:55 PM »
FE4SPDMustang
Re: Fe Engine
« Reply #8 on: May 10, 2021, 09:01:32 AM »
I had C2SE-C. The C was hand-stamped. The foundry ground the area flat and stamped them with "C" They had spring seats in them. The chamber with flat tops in a 428 make 11.5:1 compression. I had them in a Mustang and they were a pain in the butt to get the header bolts in. They also have the improved runners that flow better like the 427 LR heads.
As for Mustang Tek, it's often wrong.
Re: Fe Engine
« Reply #9 on: May 10, 2021, 10:14:32 AM »
Please tell us where so we all know.
FE4SPDMustang
Re: Fe Engine
« Reply #10 on: May 10, 2021, 04:16:56 PM »
Several applications are speculative.
Dumpling
Re: Fe Engine
« Reply #11 on: May 10, 2021, 04:42:57 PM »
Why would the factory grind off one number and then handstamp another/,different FACTORY number?
Are you sure some owner somewhere down the ownership chain didn't just make the numbers match his spiel?
Re: Fe Engine
« Reply #12 on: May 10, 2021, 06:48:34 PM »
There are actually a few different, but well known examples, of Ford doing that on various parts. I’m not an expert in 406 heads and this particular example, but it’s very common on forged crankshafts for example, where Ford machined a common forging into a couple different finished cranks. Likewise another common one is the C3AE-9425-K 427 low riser intake manifold, where the last letter, the “K”, on the casting number on many was hand stamped on. I have seen pictures of other cylinder heads where the last letter was hand stamped. I’m not saying your scenario isn’t possible, but it is something Ford definitely did back in the day. No one was looking ahead 50+ years to when this stuff might became collectible, and preventing forgeries. But this is where having hands on experience with certain parts & engines helps.
427John
Re: Fe Engine
« Reply #13 on: May 10, 2021, 06:58:29 PM »
But of course you never are.
FE4SPDMustang
Re: Fe Engine
« Reply #14 on: May 10, 2021, 07:23:04 PM »
No, FORD did this. It's commonly known about the C2SE-C heads and well as the '68 N heads. They also came with and without 427 style spring seats.
These were in the Ford box and wrap, stapled shut. I bought them with NOS 2.09 and 1.66 valves in the boxes, 427 springs and seats. The heads were cut for the spring seats. It's not a fairy tale like the 68' 427 W code Mustang.  As a matter of fact I sold them to Ben from the 332-428 FE Forum.
They're a great head except the tiny 62CC chamber and they are horrible to deal with in a tower car with headers.
« Last Edit: May 10, 2021, 07:59:03 PM by FE4SPDMustang »
Gregwill16
Re: Fe Engine
« Reply #15 on: May 10, 2021, 07:58:06 PM »
Don't mean to pile on FE4SPDMUSTANG, but if C2SE-B heads are not 406 heads, as you say, then what application are they for?
I've had a couple sets and have have seen several more and the dates on all where in 406 range, beyond any other early HP FE.
FE4SPDMustang
Re: Fe Engine
« Reply #16 on: May 10, 2021, 08:26:16 PM »
Greg: I was told by the one who has seven 406 cars that there was an interim early head. My understanding is that 390HP and a few early 406 cars got them before the C castings became available. The listings I saw in exchange books seem to be confusing because of the 4V-6V listings and seem to be convoluted as to early and late 62-3 heads. What was noted is side-side comparisons of this head and the early 427 LR heads as they are almost identical. The earlier FE's are a out of my wheelhouse a bit. I bought into the C's right. It's just that 11:4 was a problem and it was the reason I sold them and went another direction. Not to mention the never ending exhaust leaks.
I will see if I can get a hold of Jim and share his knowledge directly with the running changes on the 406. It may shed some light being he bought the cars new and that is his passion.
427John
Re: Fe Engine
« Reply #17 on: May 11, 2021, 02:42:32 AM »
Nobody doubts that the C's were 406 heads and that they were good heads,I just don't buy into your statement that B's weren't 406 which is exactly what your first post stated.Not only were the C2SE-B's and C2SE-C's used on 406's so were later C3AE-C's,and while some of the earlier heads may have been equipped with the spring seat cups if they were meant for a racing application,as I understand it the C3AE-C's were the ones that introduced the larger exhaust and spring seat cups on the normal production line.I have examples of all 3 and they support that,the C2-B's and C's weren't machined or equipped with the cups or larger ex. valve and the C3-C's are.As far as I'm concerned at least in this instance the Mustangtek information is pretty accurate.
Re: Fe Engine
« Reply #18 on: May 11, 2021, 10:25:02 PM »
I'm getting tired of deleting posts from this thread.  Let me just say again, for the umpteenth time, that a CIVIL TONE is required here.  Complaints about people whining or pointless back and forth arguments that turn nasty are NOT WELCOME here.  I don't want to start banning members, but if this continues, I will  >:( >:(
