If your rockers fit the shafts tight, then you won't have a lot of extra oil bleed off, even with .080-.100 restrictors. No reason to run .040 to the shaft, with bushed rockers in my opinion, they will "meter" the oil themselves unless they are really "loose". I ran .090 or so on DOVE rockers for years and years, no issues with over oiling, they fit tight on the shafts, no wear either. It is the needle bearing rockers with pushrod oiling only, that need the most restriction. Your pushrods are just going to oil the cups (only) and bleed a little with the lash when on the back of the lobe. A little different, but I am sure it will work, just added insurance.
