I am working on putting pipe plugs in my ’66 427 cast as a side oiler but not drilled for it. I am counting five holes I need to address.
1 – oil passage on front of block above cam
2 - Oil passage opposite end (back of block) of #1 (above)
3 – hole below cam plug on back of block
4 – plug in valley behind top opening to drop distributor thru. More to follow on this hole
5 – plug in valley at the rear of the block
That is all I see for this block other than the pressure relief valve above the cam plug but that already is tapped.
I am working on hole #4 as listed above. See sketch. This hole pretty much looks like the sketch. The 15/32” hole is an estimate. A 29/64 bit will drop thru. So I assume the hole is larger but I could not find a 15/32” bit but it’s safe to say that is the size. To tap a 1/4 NPT you use a 7/16” drill bit. Obviously this hole is already over size to tap it a 1/4 NPT being at 15/32”. However I still took the tap to see how much bite I could get. It scraped in some light threads but when I put a 1/4 plug in it is very loose. Most people say a 1/4 plug fits here. Since it won’t I’m at two options unless there is another? 1) I could put another cup plug in the hole and move on or I could open the .550 counterbored hole to 37/64” and tap for a 3/8 pipe plug. Thoughts?
I have been communicating with a regular contributor to the forum but I feel as though I am monopolizing his time. I appreciate his time but I thought I'd open the conversation so I don't occupy his time too much.
Thanks,
